hey all got the usual shit squeal with my r33, no matter what i do they sqeal
what ive done
new rotors front and back, slotted from the group buy
cheapie pads up front
cheapies at rear (different brand)
and guessing stock nissan handbrake shoes
used anti squeal, and i have all my shims
bled the system and have braided lines not like it makes a difference
bed them in properly but still got the squeal
sometimes it comes from the front, sometimes back sometimes both and yes EVEN the handbrake squeals (use it sometimes coz its so embarassing pulling up to lights on a bad day)
so the only common thing is the brake rotors... it is only when slowing down say under 30kms an hour they start to squeal
WHY WHY WHY
anyhow they weren't as bad before (still some squeal) with standard rotors and standard nissan pads up front so this is not acceptable, there has to be a reason.... cannot just say thats the way it is
anyone have anything i can try or any theories??
https://www.sau.com.au/forums/topic/195154-yes-another-brake-squealing-thread/
  • Replies 61
Posted Images
were the rotors completely clean before you took it out to bed in the pads, did they have any greasy finger prints or oil still on them, as when the brakes get real hot left over gunk on brakes tend to cook and make them squeal.
Just a thought.
I'm having the exact same problem but with stock 33gtst rotors and bendix ultimate pads. It's got us stumped, the only thing that has had any effect on the squeeling was lubing between the calipers and the back of the pads but even that only last a couple of days.
Doesn't do it EVERY time but more often than not and it's when I brake lightly coming up to traffic lights etc. Mechanic says he can feel a vibration when it does it.. going to try skim the rotors next and see if that helps.
i get the same problem, only without the vibration. i put my problem down to brake dust....
however, with a vibration, it could be number of different things. a slightly loose bolt in the caliper, shims missing or around the wrong way or even just a small stone stuck in your brake pad...
I don't think it's a huge vibration as I can't feel it, he was in the passenger seat when it squeeled bad and said it was a vibration.. I think the squeeling is a minute high frequency vibration.
I should really have skimmed the rotors when I put them on, they are 2ndhand 33gtst items. Looked fine when I put them on but the bendixz pads seem to have lipped the rotors fairly quickly :(
Edited by bubba
i would hardly think using brake cleaner would cause squeal as that is its designed purpose
i might try this copper grease just got a laugh to see what happens
just to make sure i do it correct there is 2 shim and then the pad
so...
piston -> shim 1 -> shim 2-> brake pad -> rotor
so i put grease between piston and shim 1 & shim 1 and shim 2 and even between shim 2 and brake pad?
what is actually squealing? is it the pad on the rotor or caliper piston on the backing plate of the pad? im just unsure thats why im asking. does it only do it wen braking at low speeds because you aren't putting as much pressure on the pedal and so the pad/caliper piston is only slightly engaging?
my car is doing the same after putting in bendix pads, its pretty annoying to say the least
Edited by white33gtst
I'm running bendix pads aswell, does it at low speed with light pedal application but once it starts squeeling, it doesn't matter how hard you push the pedal - it doesn't go away till you come to a dead stop.
did you bleed the brakes after resetting the caliper pistons to put the new pads in? if there is air in the brake lines would this give the caliper piston some play? that would let the brake pad vibrate slightly enough to give off the high frequency squealing?
ok just noticed u did bleed the brakes. did u bleed them at all 4 corners?
yeah i did but im going to do a full brake flush when i get the chance with some new fluid and thinking of getting some QFM pads for the front, use copper grease and hopefully i get some better results
with standard rotors and stock nissan pads it done it maybe 20% of the time but this is like 80% if not more
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
