as for the exhaust being too low?
you know that between the two axles youre allowed to be lower then 10mm
its in the ADR rules ... cant remember exactly but states something about having to be higher then 100mm forward of the front axle and behind the rear axle, but inbetween you multiply the distance of something by 33.33 ... cant remember exactly... but yeah, allowed to be lower then 100mm inbetween the two axles
VSI 8 covers ride height - http://www.vicroads.vic.gov.au/NR/rdonlyre...8340/0/VSI8.pdf
A car can be lower than 100mm, provided the height point is calculated in the VSI.
However, generally people have the issue with the cat, or rear muffler, which is within 1m of the axle generally, hence 100mm applies
thanks spunky munky, will keep that in mind if needed. yeah your right, i have always been putting it off fixing those things so now i have to do it which isnt too bad. i found out today that i might be getting advan v103's all round for a bargain price because the good guys at the tyre place busted the sales reps balls as to why there is no supply of the other tyres i chose in australia at all and the odd mismatch of yoko's available that i finally chose was a concern to them in regards to handling. top blokes hey!
thats a pretty nifty fact ruffels, unfortunately my second pipe is right under the diff..ha. 1 metre doesnt give much to play with =)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
