so the kai is for the gtr's?? i want the most responsive turbo i can get for my rb25 for street, that will run me in the mid 12's, ive heard something as small as a gt2535 could fit the bill?, but would the gt-rs be a better option?
is this a good turbo?
http://www.trademe.co.nz/Trade-Me-Motors/C...n-128263102.htm
https://www.sau.com.au/forums/topic/195302-gtr2530kai/#findComment-3498525
No, the 2530 KAI is not just for the GTRs, i got one on my RB25DET and im making 230rwkw @ 20psi with it.. Now im thinking of purchasing a GT-RS for more power..
With the 2530kai you will get great mid range power and they are very responsive..
Edited by EVL-R33
https://www.sau.com.au/forums/topic/195302-gtr2530kai/#findComment-3498626
From what I've seen all the "KAI" bit means is that a 2530KAI has housings to suit an RB series six cylinder .
By far most GT25/28 series BB turbos use a GT28 turbine housing (meaning a T28 flanged one) . The HKS is the wild card being a T3 flanged GT28 turbine housing intended specifically for RB20's and 25's .
The reason I know the guts are the same is that the cartridge numbers are all the same - 446179-21 or -5021 .
The turbo assembly part numbers I have are 472560-4 and 472560-11 . There are only three variations I'm aware of being SR/CA type , RB20/25 type , RB26 type . Their housings are unique to the intended engines layout .
If you look at HKS's (Garretts actually) GT-RS all they are is a Garrett cartridge with HKS's model specific housings bolted on .
If you buy a GT-RS specifically for an RB20/25 you'll get a port shrouded compressor housing on it , HKS obviously found out that using a compressor of that size with a reasonably small A/R turbine housing would drive its compressor into surge on an RB20/25 .
If you buy a GT2871R 52T from Garrett (same cartridge/wheels) you'll get a T28 flanged turbine housing and a non port shrouded compressor housing because its intended for an SR20 . So basically the RB version is in effect a "KAI" .
Mount flange aside you may so what ? Well the difference is that an SR20 has ~ 500cc pots and its cylinders are phased 180 deg apart . An RB six has either 330cc pots (RB20) or 410 cc pots (RB25) and their cylinders are phased 120 deg apart . Basically a 2-2.5L six is more likely to drive a GT28 based turbo into surge with a bigish compressor . Unlike Garrett HKS only do one turbine housing A/R size - 0.64 , Garrett do 0.64 and 0.86 A/R ratios but only in T28 flange .
Cheers A .
https://www.sau.com.au/forums/topic/195302-gtr2530kai/#findComment-3499145
This turbo or a gt-rs would be my turbo of choice for a streetable rb25...have seen one on a rb25 make 238rwkw at just under 17psi...with a very fat curve...and it wasn't a happy dyno too...the 2530kai was as responsive as the stockie and its not even boosted high enough yet in my opinion...i'd run these things up to 20-22psi if it were up to me...
Edited by limpus
https://www.sau.com.au/forums/topic/195302-gtr2530kai/#findComment-3499439
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
