Theres a thread or two about this in the main forums, but I'm interested in seeing what people here use and recommend. Think I need to replace my pads soon. I'm pretty sure my car is running the stock GTS4 calipers on it, looks like 4 pot on the front and 2 pot on the back. (1 on each side of the disc rear, 2 each side disc front)
https://www.sau.com.au/forums/topic/195359-brake-pad-recommendations/
i've said many times before that i swear by the Ferodo DS2500. its fantastic on the track and great around town too. they do take a little warming up, but once you stand on the brakes 2-3 times, they work great (i do mean just regular braking, not a full hard stop).
however, now i am currently using Bendix Ultimate pads as these were recommended to me by a trusted source. i've heard very good things about them, so i decided to give them a go. they are much cheaper than the Ferodo's and they are also more widely avaliable and pretty easy to get (repco etc...).
you should research and see if the r32 GTS4 calipers and pads differ to those on the GTS-t. if they dont, then you wont have any probs in finding some good pads at a resonable price...
I think a20089 tried out the EBC Yellowstuff, ask him how he went (or he could post here :w00t:. I use EBC Red, so does Derek at 5th Gear in his 32. I'm happy with mine. I haven't run them on a track for a decent amount of time but they are (IMO) good on the road.
I think a20089 tried out the EBC Yellowstuff, ask him how he went (or he could post here :yes:.
Yes I've got the EBC yellow's front and rear. I can not fault them at the moment. They are however a bit on the dusty side but apart from that they seem great. Compare the differences between the EBC pads on their own website http://www.ebcbrakes.com/yellowstuffinfo.html Pay particular attention to the cold effectiveness compared to the reds, important particularly in Canberra winter.
If you want them I'd get them from overseas, Australia wanted $300 a set on a group buy, I got front and rear with shipping from America for $300 and I could have got them cheaper. (GTR brembo pads)
+1 for DS 2500, dust comes free. i swear there's more dust than pad by weight. i understand that Performance Friction have some new Endless pads that are as good and less dusty.
I've used DS2500's in my Datto (Comm calipers/Magna rotors) and they are great. They will take some track time without fade, don't need much to warm up, last for ages and my rotor face hasn't grooved at all. Probably a little overkill for just straight street use, but worth the money. Widely used in the rally community too. As for dust, they're not as bad as Bendix Ultimates. I guess the main issue is not being able to wash your car, but of course you are allowed to 'spot wash' with a bucket.
Saw you leaving work yesterday Chris, before that had been a while since I've seen the 32.
Take it easy.
Martin
Edited by Datman
So what pads did you end up getting?
Here's another article on my type of pads.
http://www.ebcbrakes.com/Assets/vwdriverarticle.pdf
I've heard good stuff about the QFM stuff but that was from the owner, so it might be a little bit biased.
Hey this is a good topic i was wondering about this yesterday
i think i need new pads two or bigger brakes im not really sure they seem ok when ther cold and theres no squealing i just get bad brake shutter arfter a little bit of fun i think i just have the standard brakes any suggestions on what to upgrade to? and price? preferabley ones that are better when there hot, I just wanna have fun and not die :banana:
Thanks in advance for any help
Edited by R33Gtst Driver
if your getting a vibration or 'shudder', your disc's are probably be warped. they'll either need to be machined or you'll need to get new ones. they are pretty easy to find, Repco will order them in. not sure on price, but fronts would be up around the $500 (thats a guess)...
or
you might have a loose bolt or something down there if it only happens when your giving it some, but i'd put my money on the warped discs...
or
Thanks heaps.
is this because they are standard brakes or old rotors? and will it happen alot? if so what brakes should i upgrade the brakes? or just get slotted rotors?
I dont think is a loose bolt but defenatly going to check :bunny: also could it be because i have 19s on the car?
Thanks heaps.
I dont think is a loose bolt but defenatly going to check :devil: also could it be because i have 19s on the car?
i dont think its your wheels, as you need to have a damaged or buckled wheel to get that kind of feeling, and it would do it all the time and affect your steering, not just when its hot. your rotors would be warped due to very high brake tempretures, the standard rotors cant disperse the heat and gas the way that slotted/vented rotors can. if you upgrade, go the DBA 4000 rotors and Bendix Ultimate pads, which you can get from Repco or anywhere like that....
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
