i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
sif big FMIC! Mines bigger!
I can say that Jao's car is a bit of a lag beast (from what ive seen) and traction sounded like it was an issue when he fanged it up the hill, but its cool and im shitty that he has a RB20DETT and i dont! :P
  • Replies 141
my gtr greddy manifold was modified in japan to fit an rb20 by simply welding, machining and drilling extra tangs onto the flange. the ports still line up perfectly.
ie instead of \ \ \ / / \ its now \ \ \ X X \ (yea dodgy explanation but i'm sure you get it) :D
lol, sproosy, posting again i see :)
Yea i'd love to get some help to extract every single extra kw out of this thing, as it seems to be, well, under powered, any help/ideas/places to go for help? roy? :)
LOL...I dont know. :D
I am curious to know what turbos it has...can you see any markings on the housings?
on mine? Standard 32 GT-R turbos i think, suppose i could take a sticky beak if you want.
Any suggestions on what to do next to get best gains and smooth out the power curve?
Well, call me simple minded, but R32 GTR turbos have been good for 220-230rwkws at 1 bar on plenty of GTRs...i wonder why they wont make similar power on an RB20....(note i said similar power, not the same power)??????????
Microtech LT8, they can be tuned via laptop cant they? Got a copy of your tune, what sort of ignition and fuelling does the engine have. Also have you got air temp compensation wired up and tuned for?
Id say dump the cat, and have a look at the tune. My R31 GTS-X made way more power once a decent tuner had a look at the MT8. Also have a look at your battery voltage when driving next at night. My car with the MT8 went from a pretty strong 200 odd rwkws to a doughy piece of lard as the battery voltage got into the high 11s as the ignition system gave up the ghost.
A new battery, and a big ass Bosch alternator had the thing putting the numbers down way more consistantly. Are you sure your tuner knows his way around RBs running Microtecs?
Not sure of his reputation with microtechs and RB's, it isn't a very common combination. Currently tuned by Greg at Autosport Engineering in Kirrawee (Sydney). THINKING about going to Thornleigh Cylinder Heads (huge reputation, but pricey) or UAS.
Would getting rid of the cat give any worth-while gains though? My voltage sits on around 9.9 i think(or 12.1, i really can't remember). Not sure about the air temp compensation, i'd like to look into it though as i want to explore every single possibility to extract more power out of this, long term project, hoping to crack 300+ rwkw from RB20/24(maybe).
The biggest downside at the moment is that i got the car with the microtech already in it, so i can only guess what the previous tune was, and what it has and hasn't got, so in a way, im starting from scratch, well, a more painful process.
If your battery voltage is dropping that low then i would hazard a 6 pack on the fact that your car isnt making the power it should because the ignition isnt working 100%.
The MT8 was very sensitive to battery voltage, and the igniter drivers in the ECU needed a good strong voltage, otherwise the car ran like adog. The car was always a bit doughy, the car never really made much power considering all the gear on it. Then one day i noticed on the handset at night that the voltage was lower (stereo going, lights and windscreen wipers) and the car was slower then normal.
A few questions to the right people confirmed that they need strong 12V+ voltage...the car was great once with a new battery/alternator and a good tune from Quickfit in Hornsby
so are there any other places you can reccomend to tune a microtech on an RB20 in sydney? Reasonably priced too (can't get it done yet as i just bloody forked out $1100 for work on the car including a full dyno tune :D)
I havent tried many, everyone has their favourites. But i did find Quickfit (NSW Autronic dealer) very good at getting my car to drive a lot better and make better power...cant really remember what i paid, it was 6 years ago :D
Then again, it could be tuned perfectly, and thats the power it makes?!?!?!
*shrugs* i doubt it. It runs very poorly on coldstart, i know microtechs are notorious for this, but it can't be THIS bad, i don't know, i just have my doubts, i know it can be more finely tuned, well, i have a gut feeling.
Try unigroup at girraween. They have tuned a lot of rb powered cars and offer good prices.
As the car is running, it will likely only be a bit of a touch up (depending on how the current tune looks) so you could get a surprisingly cheap quote.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
