just an idea if anyone interested in a cruise and drive ins night? just an expression of interest for now, not going to happen anytime soon.. maybe when the following movies are out we can have a vote,
http://www.ironmanmovie.com/
http://www.indianajones.com/site/index.html
Mummy 3: Tomb Of The Dragon Emperor
Babylon A.D. (starring Vin Diesel)
Dark Knight, The (BatMan 2 Starring Christian Bale and Heath Ledger)
Incredible Hulk, The (Starring Edward Norton, Liv Tyler and Tim Roth)
Goal 2 (Starring, Kuno Becker, David Beckham, Zinedine Zedane and Alessandro Nivola)
http://movies.break.com/rambo/ (starring Sylvester Stillone)
I Am Legend (Starring, Will Smith)
if any movies you guys want to add feel free too, all the above movies are out during next year some early some later so just a hands up who wants to watch what and we set a date. Thank you
Edited by gtrkiet
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/
  • Replies 61
cool post now edited movie now added =D anymore movies u guys would like to see? and also what drive ins are good the only one i know is the one at gepps cross lol. if anyone know of any other good places, hit em up and also the cruise will be organised after the movie is chosen.
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/#findComment-3504450
Im in! ;)
your gonna love sitting in those fixed back seats for a whole movie :)
me and lauren went to a drive in awhile ago, it was a double movie some cartoon one and mr beans vacation. was pretty cool.
ill find out which one it was
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/#findComment-3504561
last time i went to the drive in...my battery got sucked empty by stereo/amp/sub
count me out
i'd prefer to cruise instead
the place i went to had a speaker that you attached to your window or were ever it fits so your car doesnt have to be running etc.
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/#findComment-3504597
Not a bad idea, Think Steve organised one before!!
I might be keen depends on the movie lineup but there is a movie i wouldn't mind seeing when it comes out, below is the website for the movie and also a youtube vid of the trailor
http://www.americangangster.net/
Edited by Deluxe
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/#findComment-3504669
count me out
pfft, sif not just sit their "ideling" while your whatching the movie =P
(by ideling, i mean popping flames!!! FTW!!!!) =P ...oh, wait, you dont like flames =)
https://www.sau.com.au/forums/topic/195657-eoi-drive-ins/#findComment-3505265
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
