Hey guys Just a quick introduction im new to this forum, my names Alex and i live in Melb Im currently finishing up a deployment overseas and will be returning home to aus in a few weeks. Once home i will be purchasing the R33 my dad imported about a year ago off him and plan on starting work around the begining of Feb.
The Cars details are,
1996 R33 Skyline GTS-T Series II
75,XXXKms, Manual, White
Mods: Scarely Stock and very clean a great base for some light street modding, has slightly larger jap exhaust from turbo back i think around 2.5inch from memory.
As far as i know everything else mechanicaly is standard...
Im looking at upgrading the powerside of things a little and will have a budget of around $8000 to begin with. What would you all suggest to start with? Im not looking to create a drag machine just a nice hard street tune, id like to have 200-250rwkw eventualy but do not expect to achieve this after the first stages of modding.
Some of the Items i have considered are as follows:
GReddy 600x300x80 FMIC
Apexi Power FC
Apexi SAFC
Z32 AFM
500cc Injectors
GTR Fuel Pump
EBC (unsure what brand)
Turbo upgrade (either swap or highflow)
3inch Exhaust Turbo back with highflow cat
What do you guys think? Am i very far off track? What would you do if it was your car and you had this budget? Thanks Alot for any help.
Alex
Edited by Keeffy
https://www.sau.com.au/forums/topic/196092-r33-build/
Your list is pretty complete for what you desire- Delete the SAFC, add a clutch and with your stock highflow you should hit your goal nicely, plus still look legal in the engine bay >_<
If you want to start slowly, simply add a power FC, cooler, fuel pump and clutch first, the noticeable jump from stock to ~200rwkw will give you plenty of fun for a while, then add the injectors, AFM, and highflow later :action-smiley-069:
If you think you might get the mod bug, then my advice would be to look for a clean 33GTR and start from there. As if you get serious with mods on the GTSt your budget will grow to more than the price of a GTR!
https://www.sau.com.au/forums/topic/196092-r33-build/#findComment-3510395
Thanks Very Much Sly yes i forgot to put in a Heavy Duty Clutch there somewhere haha, well those sort of figures would probaly keep me happy, in terms of the 33 GTR option i spose i would have to decide between a gtst with about 8k in mods or a GTR around the 20k mark which would probaly be fairly stock i imagen if even obtainable?
Edited by Keeffy
https://www.sau.com.au/forums/topic/196092-r33-build/#findComment-3510432
throw the highflow out.. add a nismo coppermix clutch kit.. add a hks gtrs kit and youll be munching anything :D a solid 250 kw with the best response :D
add in a HKS boost controller or an Profec e-01 if you can find one.
i can tell you, the clutch wont let you down at all. and the gtrs will make u smile for weeks on end :)
https://www.sau.com.au/forums/topic/196092-r33-build/#findComment-3510906
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
