Had the car on dyno the other day and my sard 800cc twin spray injectors are getting to 95% duty cycle running 575rwhp
Have a sard rail, sard reg and 044 mounted in tank...
From what I have been told the 044 is probably running outta flow, hense the high injector duty cylce. I have not checked the fuel pressure since we set it with standard fuel pump in but I'm going to assume its still at 3bar.
2 questions!
Would it be worth bumping up the fuel pressure to say 3.5/4bar to get a bit more injector clearance or will this cause issues?
And what thread do i need for the Sard FPR to put a gauge on, is it 1/8 NPT?
Cheers
Simon
https://www.sau.com.au/forums/topic/196162-some-fuel-issues/
400rwkw is the limit usually found with a single 044 pump.
you could bump the pressure a bit, but remember whatever boost you run that pressure adds to your base fuel pressure. i.e 50psi base and 30psi boost = 80psi fuel pressure.
i would look at twin pumps myself, if your going for more power, or up the pressure a little to see if its possible to lower the duty cycle a bit if you are happy as it is.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
