Hi Guys Girls and everything in between,
Can some of you make some suggestion to how i can increase the power output from my R34 Gt-t Tiptronic i currently have 124kw i would be happy with something around the 180kw range.
I have had some suggestion from running full 3" Turbo back exhaust, Full Front mount intercooler and boost to 12psi has anyone tried this and can provide feedback???
Thanks
https://www.sau.com.au/forums/topic/196241-more-power-from-r34-gt-t/
A exhaust, FMIC, boost controller, and SAFC will get you around 200kw at the wheels. I would get a tune first as I have a bog stock one and am getting a lot more than that at the wheels. Maybe check your plugs, fuel filter, airfilter etc.
What are you getting out of interest? auto?
Mine is 138kw running 9psi through the stock exhaust (which is definately holding it back).
If you're only looking at < 200kw, then you can probably skip the FMIC on the 34.
Powerfc won't work with the auto (there are mixed thoughts on this), but emanage ultimate will definately be a better option over the SAFC.
But exhaust should be your first step, then wind up the boost.
I have the FMIC ready to go on this weekend, currently its putting out 124rwkw stock standard nothing diff on the car that was running normal fuel.
The guy who did the dyno run for me was saying with a decent size front mount, 3" turbo back hi flow exhaust, boost controller and 12psi should get somewhere around the 180rwkw. Tell me guys is it really that big of a thing the change the computer i was kinda hoping to avoid the expence. Excuse the ingnorance but i am new to turbo cars give me a good old 4, 6 or 8 cylinder and im sweet ha ha
If you're only chasing 180kw then the boost controller and full exhaust would be all you'd need.
General concensus is the stock R34 SMIC hits it's peak around the 200kw+, then again a cooler intake charge is always a good thing which is what the FMIC will give you
Good idea to get a SAFC NEO to optimise your mods,
I'd personally get a replacement ecu like power fc as the tuning bug inevitably bites again after awhile.
1. full exhaust
2. fmic if you want
3. boost controller
4. SAFC or ECU
My 33 is puttin out 183kw
Pod Filter
Power Fc Tuned by Re Customs
Stock Boost solinoid is allowing 10-11PSI simply with the aftermarket exhaust (mostly helped but the split dump pipe id say)
I wouldnt be too stressed about a fmic if you just after the 180 mark, specially since you got a 34. But on the other hand why the hell not :nyaanyaa:
ECU is the way to go. or at least some sort of air/fuel controller otherwise you wont see the full potencial of you mods. The stock computer will detune itself as a protection mechanism. Or worst case scenario the car runs lean. but at these power goals i dout leaning out should be to much of an issue. running rich is far more likely.
Get a frontmount, a good CAI (with Pod), full turbo-back exhaust system, boost controller, a BOV and a good ECU or piggy-back ECU then you will hit the 200 kw mark.
FMIC+POD= defect in vic and possibly other states, FMIC is un-nessesary for R34's for 200rwkw. Just get an apex'i panel. great quality.
Full exhaust with high-flow cat is a must
Boost control, Jaycar IEBC is good value for money. or if you can afford it, blitz ID3 is known to be good.
BOV is a waste of money, causes issues with AFM cars, and doesnt improve performance, when your stock once starts to leak, get one GTR unit.
if on a budget again use a jaycar DFA, if you have money get an E-Manage Ultimate(EMU). If you go the DFA route, look for an Apex'i SITC second hand if you can, my theory is when going past a DFA(getting an SITC, i would just get an EMU)
So costs here are:
Apex'i filter: $80
Full exhaust: HKS catback from justjap for $800, GKTECH or Justjap front/dumps, ~$200 Highflow cat: PM BATMBL, think they are ~300 So max $1350 for a full exhaust
Jaycar kits: IEBC $70, DFA 70, i think the hand controller was ~$50 Apex'i SITC ~250
Tune shouldn't be over 300?
So the grand total Shouldnt be over $2200 if you get an SITC and allow 300 for the tune. OR under 2800 with an EMU
Cheers,
-Ryan
Hey Guys,
Budget is currently about $3000,00 over the next few months so i should be alrite there. I bought a bloody Just Jap intercooler kit the passenger side piping is sweet and there ain't no way in hell im cutting a big bloody hole in the side of my car i think i will reverse the intake for the cooler and run it back through the orig pipe work least that way the coldest air will be running straight into the engine and not passing the radiator 1st, can anyone tell me if $1280 is a good deal for a full Turbo back exhaust 3" should i be asking for a split dump pipe???
Edited by Nic & Dee
FYI, I have a 2001 R34GTXT, and with CES turbo back exhaust (www.cesracing.com.au) K&N Panel filter, and with boost naturally rising to 10-11Psi from the exahust upgrade, I managed to achieve 174rwKw @ the wheels. With the boost screwed to 12Psi with the $22 Turbotech bleed valve, I was able to squeeze another few kw to 181rwKw.
No other mods needed for this output and the car is my wifes daily driver. The car also see's regular track days during the colder months of the year, although with 2 kids the car has lacked track use this year.
My budget is not very high, Mark at Hills motorsport suggested starting with FMIC, Turbo back exhaust with split dump pipe full 3", decent boost controller and lock the boost at 11 or 12psi. I have budgeted for $3000.00
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
