  • Replies 318
just starting out - use street tyres.
You learn your limits and control with street tyres. Do that for a year or 3 then get some semi's on seperate rims :D
No real toys to talk about,
Dejetro PFC and no airflows and greater adjustable top control arms, thats about it.
I would like to have a 2nd switch able oil cooler in before I go so I can at least have 10 min sessions.
P.S. I will only be in if the weather is cool, forecast for that week is hot
Wednesday 2nd Jan
Mostly fine.
West: Min: 18 Max: 30
Thursday 3th Jan
Mostly fine.
West: Min: 20 Max: 32
yeah im back in action for the time being. was a great day and lots of track time and not much traffic at all.
was soo much fun.... cant wait to get back out there agina.... but would have been great if i had some sort of timing, ill have to look into that in the near future. i was however having overheating problems with the watertemp getting up to atleast 120 most of the day/ will have to sort that out soon.
you little prick! you went with out me!!!!
ps. glad you had fun, I couldn't make it that day anyway
I'm thinking next week might be a goer for me.
well that was the best time i have had in ages!!!
had a few spinouts but after 4 or 5 sessions i was starting to drift that last corner nicely...omg so much fun! sideways forever!
i will going to these more often...
need to organise a big sau day out there~
its just gonna get expensive with the tyres and all...semis would be nice or atleast a harder compound.
oil got up to 130deg so ibetter get that cooler on and at one point my water temp was 105deg.
found a few bugs in my setup which i'll try and sortout before the next one...cant wait!
haha good to hear you enjoyed it out there. Always amazes me how gtsts can just go hit the track for a day in the middle of summer and survive.
ultimately a set of good semi slicks will be cheaper than wrecking your road tyres, but they are a bit tricky to learn track driving on because the better they are the less warning they give you when they are about to let go.....
In case people aren't aware
This was in the email I got weeks ago....
$130
From 2nd January 2008 to 9th January 2008 Grand Prix Circuit
11th January 2008 to 13th January 2008 Grand Prix Circuit
I have an exam on the 8th so........I could be tempted for another round anytime after that.
yeah price increase opf 10 bucks!
FW - when did you go - today??? f**k it was hot out there!! I got sunburnt at the beach, I was glad I had my r31 out not the 33!!
Id seriously suggest you stick to street tyres for a few more days on the track. learn the limits on them, then after alot of confidence etc etc, move to the semis.
bascially - do your bestest time on street tyres - then do semis :P
Glad you had fun however drifting last corner at OP with those walls - nah, Id pass!!!
every other corner yes!! but last corner? nah....and I can drift :D:thumbsup:
yeah today evil, was mad but hot. i will stick to street tyres for quite some time while i learn how to drive the car properly...
last turn is awesome....i found it the easiest to drift...
you found it the easyest because its off camber and thats y so many people end up in the wall so be carefull not that i can talk when i was there i was drifting that corner in the wet but i was doing it in a race car so if i crash that i can still get to work.
Where the hell have you been hiding Paul!?! :)
I had a month overseas and then I have been flat out with the pool fence business and usual work since I got back. Here is a pic you might like. When I get time I will start up a shameless promotion post.
+1 :)
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
