  • Replies 107
back up for sale...$49,000...come and get it. I know people who spent close this amount on an engine and gearbox rebuild!
or will separate chassis, gearbox, turbo kit, engine package etc. Dogbox just had a recent overhaul and is 4 passes old...shifts very fast and crisp.
The car ran pretty lazy 9.40's and 9.50's at Jambo on only 29.6psi max during the runs which is nothing for an engine package of this calibre.
Edited by Red R Racing
New HKS T51R SPL BB turbo kit (modified to new HKS T62 spec compressor rated at 1150hp) all ceramic coated with high temp black on turbine and manifold. Cerami-chrome on compressor cover.
New HKS GT-II 60mm external wastegate.
New Earls braided oil and water lines.
New CES 5 inch stainless dump pipe and wastegate pipe both coated in high temp black.
New PPG fully optioned billet straight cut dogbox. (just been reco'd...done 1 pass)
New NPC race twin plate clutch with billet flywheel.
New Nismo 2 way rear diff.
New modified transfer case done by Award Diff and Gearbox.
New fully optioned Vi-PEC V88 ecu with 7 bar map sensor and plug-in adaptor.
Thats over $25000 dollars worth!!!
Quite a few items have been deleted from the original post as the car has progressed lately but most of these items were replaced with superior parts for racing or removed due to unnecessary weight...they are...
Bride Brix II recliner passenger seat
Willians 2 inch passenger harness
Autometer NOS gauge
Apexi Power FC ECU
New Z32 air flow meters
Blitz ID3 boost controller
Blitz ID3 power meter
G-Tech PRO RR with laptop interface, software etc
Carel inlet temp meter (fully programmable switching outputsOS Giken 5 speed gearbox with upgraded input shaft
C's short shifter
HKS GT-RS turbo's (modified by Croydon racing)
HKS 1.2 bar wastegates
HKS stainless manifolds Hi-temp black coated and ported and matched to head
HKS stainless dump pipes Hi-temp black coated and ported for increased gas flow
Cusco front tower brace
Cusco rear tower brace
Auto-select front A pillar braces (rare)
Bosch motorsport 040 in-tank swimmer pump
2 x Bosch motorsport 044 external fuel pumps
Performance metalcraft surge tank
custom perspex fuel system enclosure
Sard fuel pressure regulator
Blitz 1000cc injectors
Trust twin entry fuel rail
-6 braided fuel lines and Earls fittings throughout
twin Bosch motorsport fuel filters
Custom black R34 GTR rims with centre caps
Toyo street rubber
Full NOS 75hp wet nitrous kit including bottle warmer, gauges, brackets, 10lb bottle etc (never been used)
Forgot to add...
20 litre boot mounted fuel cell
Magna Fuel 650 2000hp fuel pump
Magna Fuel 750 micron pre pump fuel filter
Magna Fuel 250 micron pre injector fuel filter
Hypertune Billet 14mm twin entry fuel rail
Aeromotive fuel regulator (the big one)
Bosch 1600cc genuine Indy Blue injectors
$1000 worth of -10 and -8 braided lines and fittings
This system is capable of supporting over 1000hp on E85 and will out support the turbo kit on race fuel. It runs a -10 feed up the car and splits into two -8's into the rail...it runs a -8 return back to the fuel cell.
Guest
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
