hey guys i have read all of the threads about ecus in auto r33s
all of them are from quite long ago
there would have to be advances in tech
so would are good ecus for auto skylines now
dont want extremely harsh gear changes
also i was searching on ebay for ecus and i found reprogrammed standard ecus
this is their description
Here is a Japanese tuned ecu by Garage50 tuning workshop this ecu to suit a RB25DET it puts out over 200rwkw @ 12.5 psi with only a front mount and dump pipe and 3" exhaust and bleed valve. it has the speed limiter removed and the boost cut removed also. If you raised the boost you will easily have over 300rwhp, and would get even more hp with a bigger turbo and other mods.This ECU puts out great low to midrange torque with the standard turbo which is great for drifting. Fully tested and working, I try to get all the ecus that i sell onto our dyno to check power output and more importantly make sure they have a safe air/fuel ratio and will run our fuel. We have had great success with these ecus and our feedback proves the results. This has been tested in both Manual and Automatic R33 Skylines series 1 and 2. This is the last one till Feb 2008 as i have stopped importing until next year.
has anyone had any experience with these ecus
is it worth getting somethinglike this and where would i get it retuned in wa
cheers
https://www.sau.com.au/forums/topic/196439-auto-ecus/
Dont overlook the PFC, I have one in my R33 GTSt auto and have had no problems, (as have others)
Have yet to find somewone who has tried a PFC and had a problem (others only know of "someone" that had the problem, but we can never find "someone" when we look)
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3515835
hmmm interesting, magical removal of things that don't exist.
This is a good enough reason not to buy anything from that buyer.
people call boost cut different things. boost cut is hitting a higher afm voltage at a lower rpm i think it was around 3.8v @ 4000rpm and 4.1v @ 5500rpm (i think). programs like the emanage, safc and remaps have the paramters to overcome this.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3516249
the wrx's run off a MAP sensor to read boost. when the MAP reaches a certain voltage then it initiates the fuel cut - same as ours except the ecu reads air flow rathe than pressure to cut boost.
the wrx's can be tricked by putting a restrictor in line with the map sensor that reads boost (in their boost solenoid). what this does is moves the boost cut threshold up by a few psi. we try to do the same with the emanage and safc. we 'trick' the ecu by making it read a lower afm voltage by inputing one that would not initiate the fuel cut.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3516383
pfc for the win.
enough said.
https://www.sau.com.au/forums/topic/196439-auto-ecus/#findComment-3517895
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
