Future plans for us turkeys and our cars :) care of gordo
  • Replies 160
hey good work!!
will be thumping.. so do you have any plans for it?? I guess its got soo much done to it there probably isn't heaps that is easy
these wheels would look good on it..but they're from japan
wind down the boost to give less power.. probably a first in the skyline scene..hehe :) but yer, 400rwkw couldn't be fun when its raining.
I have a few plans of getting the most of my car, and hopefully learning a few things over the next couple of months... but i think unless i have a major change of circumstance I'm going to sell it b4 the end of the year :-(
but i have bigger and better plans for my next car.. and wanting to work from the ground up this time i think, do every thing my way.. and probably install most of it myself to save costs. Think I'm in a position to install most of the usuals myself..
still not sure exactly what i'm getting, few options.. think i'm going to give importing a go - once SEVS is up and functioning properly.
haha, thats awesome...
You'll get used to it eventually though. Will be fun to take it down the 1/4 - you'll get so many looks and stuff.. Better set a good time or you'll get abused - you got the car now there is no excuse about the driving :)
ahh the never ending plans :D
i always say to myself after a mod "...and THATS IT! not more!"
the car is currently at Palm getting the bonnet, front bar, boot and new stealth wing (when it comes in later on this week/next week) resprayed
bought the wheels last week and im happy with those
now, the car will have to wait for abit till the money tree grows a tad then its turbo option time
1. highflow
2. straight bolt on aftermarket
3. go the whole hack, manifold, external gate, td06 *shrugs*
well see once the time comes around, then ill make dead set decisions
u really want the widebody kit for the R32? never been a huge fan, but its something different i guess. post a pic!
I'm thinking GTS4 too, if not a good ol gts-t will do.. around $10k ? maybe being too optimistic there but not sure.. then spend $5k on the "minor mods" (kit, exhaust, Fmic, boost, etc) to get it to around the 170kw wheels mark.. then think about thinking about trying to get it to 250 kw or so at all 4 via something or other turbo...But i'm in no hurry. May just do stage 1, save the money for my house, adn get a 1990 R32 GTR under the 15 year rule in 2005 if its still around then (thinking way too far ahead.. lol)
Still also thinking the 180 for number of reasons, even though people might disagree with me..
possible a tt-soarer /me waiting for the slap from inark
I don't think I will be doing mine till right till end of this year, start of next year. Might think about a worked 89 model of "whatever", but will have to think about that a bit more.
whistla: what happened to your bonnet? I think i've only seen yours once, but it looked damn clean to me :(
haha..yer, i consider that for my 33.. but well i don't want to spend another $8k which i know will be hard to get like $30k for mine.. sure it might be 270rwkw, but its a pretty limited market for buyers.. you gotta be keen - not many p-platers can afford that :D
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
