WE WANT YOUR BLOOD!!!!!!
When: Meet at 1730 (5.30pm) for 1745 leaving (sharp)
Where: Cairns Central Carpark (top level). We will be meeting here for pics. The plan is a quick cruise down through town along the esplanade to the Cairns Base Hospital to GIVE BLOOD. After we will all head out for dinner at the Cock and Bull
Why: Cairns and the surrounding areas are critically low on blood supplies. Every drop helps. And that is where we come in
Everyone welcome. And bring all your friends as the more blood the better
Look forward to seeing you all there
Thanks
Joe
https://www.sau.com.au/forums/topic/196627-fnq-skyline-charity-cruise/
As this is an SCC event I will pin this topic...
This is the first time FNQ (far north qld) has done this and I hope all goes well for you and your able to grow the presence...
Good luck and have a nice day out in the sun... :rofl:
Thanks Col :)
Hopefully we will get good numbers.
yeah im in
i'll go first and show you girls how its done
I am in!
And i'll go last so u can all be watch me, the big giant, reduced to a squealing and whaling mess.
I hate needles. Can i give em money instead lol
very very cool Joe... great idea. Sorry i will be away for this.
Stuff like this really seperates us from the 'hoons ' in the public eye methinks...
good work
Well done.
thanks chris. Shame that you will be south for this.....
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
