Item: 1989 R32 Nissan Skyline GT-R
Website: Performance Forums, BoostCruising, Nissan Silvia, Skylines Australia, Carsales
Item Condition: good
Price and Payment Conditions: $16,000 with RWC or $15,500 AS IS
Extra Info:
Car itself is a 1989 Nissan Skyline GT-R
I am the 2nd Australian owner.
Colour is white (must of had respray in japan, as engine bay is black)
Car has 143XXX kilometers on the tacho
Fitted with R33 RB26 Engine, KM's unknown, have compression test from when i purchased it with 150 across the board (Engine number: RB260565XXA )
Aftermarket Oil Cooler and Relocation Kit
remapped ecu (unknown, came with car)
M's pod filters
Trust 3" Exhaust front pipe to back (quiet)
M's boost controller at 1Bar
Omori Boost Gauge (fitted where stock gauge used to be)
Sony MP3 head unit (not pioneer as pictured)
R33 GTR Wheels
Aftermarket Brake Pads and Rotors
Genuine N1 Bodykit (front vents, front bonnet lip, sideskirts, missing rear lip spoiler)
N1 fibreglass copy rear bootlip spoiler
Trust rear pods
Aftermarket steering wheel
MOMO Shifter
Turbo Timer
Lowered Springs (brand unknown)
HICAS Lockbar (still have original hicas gear if wanted with car)
Heavyduty Clutch
Splitfire Coils
Seat Covers
Recently serviced with new oil and sparkplugs
Has rego until Feb.2008
I may be possibly interested in a cheaper car as a run-around, but would much prefer cash in hand.
Contact Details: Via PM for more details
Pictures:
img1402ou1.th.jpgimg1403yo0.th.jpgimg1405vp4.th.jpgimg1407ff0.th.jpgimg1409ma6.th.jpg
Edited by -==L=a=N=c=E==-
https://www.sau.com.au/forums/topic/196694-bne-1989-r32-skyline-gt-r-with-mods/
  • 5 weeks later...
Misfire fixed with replacement of splitfire coils, ignitor and CAS.
A/C fixed with replacement of magnetic clutch engagement coil.
Car also now comes with Fibreglass N1 rear boot wing painted and fitted.
Price now at $18k negotiable.
Appears the market for GTR's has had the guts fall out of it.
As such, i've readjusted the price to suit.
$17k firm
Free bump, Market hurts at the moment, I feel your pain.
Fact of the matter, if we want a really quick sale, i'd have to take $15k. There's a loss and a half.
Trade in, the max i've been offered is around $16,500. Might be an option.
hey just thought id mention that all 32 gtr's have black engine bays standard it does not neccesarily mean its been resprayed.
theres a vin number checker thing someone on the skyline page ya can search ya number and they'll tell you what colour it came out the factory with
Yeah i did that when i bought the car, it was Gun Metal Grey as standard.
No GT-R built in 1989 was white. So it has been repainted. Not that there is anything wrong with that. If the engine bay is dark grey it was almost certainly a dark grey car.
Most white GT-Rs from the factory have a white engine bay. Mine does.
no worries. its basically whoever gets to it first.
Got another guy who looked at the car yesturday, and his waiting to sell his, so just a matter of time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
