Item: 1989 R32 Nissan Skyline GT-R
Website: Performance Forums, BoostCruising, Nissan Silvia, Skylines Australia, Carsales
Item Condition: good
Price and Payment Conditions: $16,000 with RWC or $15,500 AS IS
Extra Info:
Car itself is a 1989 Nissan Skyline GT-R
I am the 2nd Australian owner.
Colour is white (must of had respray in japan, as engine bay is black)
Car has 143XXX kilometers on the tacho
Fitted with R33 RB26 Engine, KM's unknown, have compression test from when i purchased it with 150 across the board (Engine number: RB260565XXA )
Aftermarket Oil Cooler and Relocation Kit
remapped ecu (unknown, came with car)
M's pod filters
Trust 3" Exhaust front pipe to back (quiet)
M's boost controller at 1Bar
Omori Boost Gauge (fitted where stock gauge used to be)
Sony MP3 head unit (not pioneer as pictured)
R33 GTR Wheels
Aftermarket Brake Pads and Rotors
Genuine N1 Bodykit (front vents, front bonnet lip, sideskirts, missing rear lip spoiler)
N1 fibreglass copy rear bootlip spoiler
Trust rear pods
Aftermarket steering wheel
MOMO Shifter
Turbo Timer
Lowered Springs (brand unknown)
HICAS Lockbar (still have original hicas gear if wanted with car)
Heavyduty Clutch
Splitfire Coils
Seat Covers
Recently serviced with new oil and sparkplugs
Has rego until Feb.2008
I may be possibly interested in a cheaper car as a run-around, but would much prefer cash in hand.
Contact Details: Via PM for more details
Pictures:
img1402ou1.th.jpgimg1403yo0.th.jpgimg1405vp4.th.jpgimg1407ff0.th.jpgimg1409ma6.th.jpg
Edited by -==L=a=N=c=E==-
https://www.sau.com.au/forums/topic/196694-bne-1989-r32-skyline-gt-r-with-mods/
  • 5 weeks later...
Misfire fixed with replacement of splitfire coils, ignitor and CAS.
A/C fixed with replacement of magnetic clutch engagement coil.
Car also now comes with Fibreglass N1 rear boot wing painted and fitted.
Price now at $18k negotiable.
Appears the market for GTR's has had the guts fall out of it.
As such, i've readjusted the price to suit.
$17k firm
Free bump, Market hurts at the moment, I feel your pain.
Fact of the matter, if we want a really quick sale, i'd have to take $15k. There's a loss and a half.
Trade in, the max i've been offered is around $16,500. Might be an option.
hey just thought id mention that all 32 gtr's have black engine bays standard it does not neccesarily mean its been resprayed.
theres a vin number checker thing someone on the skyline page ya can search ya number and they'll tell you what colour it came out the factory with
Yeah i did that when i bought the car, it was Gun Metal Grey as standard.
No GT-R built in 1989 was white. So it has been repainted. Not that there is anything wrong with that. If the engine bay is dark grey it was almost certainly a dark grey car.
Most white GT-Rs from the factory have a white engine bay. Mine does.
no worries. its basically whoever gets to it first.
Got another guy who looked at the car yesturday, and his waiting to sell his, so just a matter of time.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
