  • Replies 40
  • 5 weeks later...
hello friends :D
just a warning i have seen this guy driving around he drives it like its stolen do a full check
WTF lol, yeah I modify a car and make it bulletproof to cut laps and look cool.......not. What were you driving when I blew you away, and I live in Frankston, cant say I've ever been to Preston in my car, did go to Darebin in it like 3 years ago once.
Hey i have a R32 GTR you might like
Gunmetel grey
19in axis rims
kumho tyres
full rebuild engine 8000km ago
ACL race series pistons
Eagle Rods
Hi Octane Racing 9L sump
Greddy Oil Pump
Gates racing T/Belt
Extreme Clutch
Tomei Dump pipes
2 x New N1 28/60 Turbos
Apexi Power FC and H/C
Sard 650cc injectors
Sard fuel pressure reg
nismo fuel pump
trust intercooler
Tein coil overs and caster rods
3in turbo back exhaust
recaro drivers seat
Greddy cam gears
splitfire coil packs
DBA front and rear slotted rotors
EBC Green stuff pads front and rear
Seabelt harness
Greddy Pro Fec B spec 2
nismo gear knob
new hand break and gear stick boots
full year rego as of 7th of feb
umm i think thats it
It's making 300KW at all four on 1.2 bar
car has done 112000km but engine has done around 8000 km's
I want 28k
What do you think????
Nick 0424407528
Edited by nickbent85
Very nice 32 Nick, thats about 3 I have been offered, would look nice next to my 33 GTR. I am still deciding between a handfull of cars.
One problem, my car is advertised for $35,000, the $28,000 is a cash only price, as cash is what I currently need, and I would sell whatever car I traded for after a couple of months. So I would need a cash adjustment.
The reason for the 2 prices is the shitty import market at the moment. Most 32's are struggling to get $19,000-$20,000 at the moment, and having built a 450rwkw GTR that I currently own, I know how much it costs to build a car like yours. Problem is we will never get close to what we spent, so $28,000 cash or my cars value is $35,000 for a trade.
I have spent around $40,000 on my S15, plus the $40,000 purchase price makes the resale value of modified imports a joke.
Good luck with your sale whatever you decide buddy, I hope you get what its worth.
hello friends ;)
Hello friend.
Thanks for your information.
Would you like to taste my penis? it is also rich in flavour. or so your mum tells me.
Hey dude its Ben, houghs mate.
i have personally driven this car and it drives like it just rolled off the showroom floor.
there are no rattles creaks or anything. Gearbox is about as tight as you could want. the car is always warmed before driving.
good luck with the sale mate. the new owner definately will not be disapointed
No more chatting in this thread thanks guys.
Do not post unless you are seriously interested in purchasing this vehicle, otherwise warnings will be handed out.
Thank you.
Admin
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
