I like the idea of limiting speed for P platers cars. Maximum speed on aussie roads is 110. There has to be some sort of ECU control that can be fitted to cars to limit them from exceeding that speed. Dont get me wrong, that speed is still dangerous, but every bit faster youre going, the more damage its going to do.
Or even better, have the ECU speed restriction and make the ecu control the acceleration. Aint going to be any P platers dragging if all their cars take 15 seconds to do 0-110 and then they are maxed out.
I know in reality, while this would be the safest type of restrictions you could put in place, it isnt viable due to the scale and cost of the whole thing. But I think if they cant accelerate fast and they cant reach high speeds, alot of your problems are solved. That type of acceleration restriction, would affect the power output of any engine enough to stop things like burnouts too.
  • Replies 41
People cant drive. There is no such thing as a talented everyday driver. the fact people learn how to drive from their parents in most cases, is the most god damn rediculous thing ever. Why should anyone be able to teach this important skill when they have no idea what they are teaching.
The scariest thing about instructing people how to drive around a track fast is realising that i drive on the road with them. 95% of people have never pushed the brake pedal to the floor. most people who get the car into a slide have no idea what to do and in most cases they are oblivious to whats happening around them. And these are people who have an interest in driving!
My point is people cant drive, and no matter how many restrictions are placed on speed, modification and age, there will always be the underlying fact that most people have no idea what they are doing and until everyone is put through a decent driver training course (not that simple murcotts stuff where you do a few stops at sandow) we will not see the death toll come down. It hasnt yet.
Condolences to the families.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
