R32 GTST 217.2KW AT 11psi $21k
93 model gunmetal grey 5speed
rb25 motor with 48k
has made 217.2KW at wheels will run easy low 12s
600,300,75 front mount cooler with polished stainless steel piping
stage 2 GCG turbo 450hp
2litre surge tank, bosch 450hp fuel pump
17" white deep dish circuit racing wheels
DBA gold slotted and drilled brakes all round
Apexi air fuel controller
Apexi boost gauge
Sard turbo timer
three inch exhaust off the turbo, stainless muffler
top of the line kenwood head deck
bilstein suspension
Malpassi fuel pressure reg
sunroof
GTR front bar
5 button ceramic race clutch
HKS super seq bov
very clean car all round, regretful sale $21,000 ono contact josh on 0410690026 Sydney
https://www.sau.com.au/forums/topic/19703-r32-gts-t-rb25-very-quick-car/
  • 3 weeks later...
  • 1 month later...
has 420hp turbo, apexi power fc computer, apexi electronic boost controller, wing, front lip, lowered, full exhaust, cd player, amp, splits, black with red pearl, low kms, always serviced, sti arms and sti close ratio gearbox, etc etc.
Yeah mate can you send me pics, my 32 with much the same stuff that made 316kw was stolen and burnt out waiting for the insurance pay out b4 I can buy. [email protected] Cheers Matt
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
