Hey guys just brought an R33 GTST it is gun metal grey, GTR boot spoiler, coil overs, 18 in rims (Work Rims) but other than that standard. I was at the museum the other night when yez were there must say you guys have a lot of members.
1 quick question though........as per every other 25 yr old skyline owner i'm wondering what the max psi a stock engine with 98,000kms on it can take with just the standard intercooler ?
I will try and get out to the next cruise you guys do !!
Cheers.......Flamin'
https://www.sau.com.au/forums/topic/197063-hey-guys-new-act-r33-owner/
Welcome Flamin
I'm not into the 'lines, but these guys are - and they are all a great bunch of guys and gals.
Sit down, relax and make yourself at home...... :P
Oh - and BTW - you better get pics up of your ride...real quick!!!
Edited by SteadyEddie
Hi Flamin, did you come up and introduce yourself? Which one were you? (i.e. real first name)
Another R33 Gtst in Canberra, wow :( Jokes...
Welcome.
As for your question, if youre running a stock side mount cooler and stock / near stock exhaust, my advice would be - dont turn the boost up at all.
Get yourself a decent front mount and 3" mandrel turbo back exhaust, then turn the boost up to 12psi (thats about as much as the stock turbo will handle).
If you turn the boost up without doing some inlet and exhaust upgrades you wont be happy with the result and you have more risk of damaging the turbo.
Oh and an oil catch can is a good idea to because if you turn the boost up on a standard turbo they usually start to blow oil through the inlet.
Just my advice, take it or leave it :)
yeah I own Karl's old car now and yes my name is michael and yes that sounds like me at the museum on friday night with the odd resenator !!
will get pics up asap oh by the way thanks for the advice on boost !!
:D
hey whats this about the museum? is there a regular meeting ^^ im new can you tell :bunny:
Check out the "Friday Night at the Museum" thread, people meet there from approx 9-930pm every Friday and yarn, exchange ideas, learn a lot. Its very friendly (sh!t stirring excluded) and we don't bite at all... well not hard anyway :cool:
Check out the "Friday Night at the Museum" thread, people meet there from approx 9-930pm every Friday and yarn, exchange ideas, learn a lot. Its very friendly (sh!t stirring excluded) and we don't bite at all... well not hard anyway :w00t:
sweet ill try be there this friday :) i need to check out the competetion :) and get advise
Edited by R33Gtst Driver
Welcome.
When I did the front mount and exhaust, my turbo was naturaly pushing upto 15psi at times which is when the stock computer was cutting out. I never had any problems and that turbo still has no shaft play and no problems. Its probly worse for the engine though.
Welcome.
15psi wont hurt a healthy RB25DET, I run mine everyday on 18psi at the manifold (21 at the turbo) and its a daily driver... I do have an adjustable computer though, so my AFR's arent stock. :D
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
