OK so I ran a search and looked here and there, many running a few piston types and brands. Looked through the thread in the quick ref as well. Something that seemed to be missing from many of the threads were a few possible choices and perhaps some info. I am wondering why I don't see many if any Jap brand names being thrown around, is it purely price? So far I have learned Venolia are at least 'buyer beware' and most others are quite good as long as the clearances and ring choice are right. That and the engine builder doesn't do something dumb :D
So how do the Jap brands stack against the more common ones I see here? Is it purely jap brands are too expensive or are there other issues? How many actually manufacture their own or are just reboxed?
JUN
Tomei
HKS
Wiesco
CP
JE
Arias
ACL
https://www.sau.com.au/forums/topic/197191-piston-choice/
jap brands tend to use the best pick of piston manufacturers and use specific models, ie the trust pistons i use in the top SR's i build use a crown design and special ceramic coated rings only available under license through trust even though the manufacturer makes "other" SR20 pistons.
Arias are a good budget brand and i use them mostly on budget builds but i am not a fan of dished crown in any HOT SR20 i prefer the flater notched crowns, i am currentley building a test engine with SRP (JE). so i will soon know what they are like.
i dont know of any jap manufacturer that manufactures their own pistons but most are made to spec and are not available in another brand or boxes, they are made under license.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526353
Interesting. Personally I am looking at a Tomei forged piston kit for my RB25DET however I'd have other things to sort (like being able to drive while R33 is off the road) before embarking on a full rebuild.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526368
you need to look a a few things to determine whether or not you 'need' the extra benefits offerred by these dearer pistons, on many builds i will talk a customer down and prefer they spen money elsewhere for their application but for extreme and high hp and high rpm i prefer the jap brands as they tend to offer a better life cycle and in SR's they offer a unique crow design and ring combo..... oh and zero noise.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526392
Mostly what people think are a good piston rather than actualy using them but still a bit of info there.
So JUN/Cosworth, HKS, Tomei if you're 'loaded' or chasing big power figures otherswise CP, Arias, Wiseco etc will do the job cheaper. Venolia if you want to brake something.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527462
ACL and CP pistons are both very good pistons for the pricing... I personally prefer ACL as they have a better ring kit... Piston wise they are both very comparable quality....
I'm personally running ACL pistons and have had no problems
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527639
you say hks and jun pistons if u chase big "power figures" who said u cant make 1000hp with a set of CP's? a set of well made forgies is what you will need. You can get a rebuild kit from racespec for a couple grand..
Edited by LTHLRB
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528520
i can see where he is comming from though. he said some manufacturers have certain technologys which is only available by licence so you will need to go with the jap brands that have this available to get it.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528527
what has stopped the old boys from making 800hp in a big block v8 n/a?
if you want to have that backing then yeah use jap brands.. but i would only use jap brands if im using a full kit (stroked engine) like full hks, tomeii or nismo.
just talking like this because iv seen ALOT of engines built with arias, acl, cp and wiseco
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528557
nothing is stopping anything. i have ACL pistons in my engine as im not made of money.
I would like to have the jap stuff in my car though.. they build more RB engines then us... well that might change soon though lol
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528858
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
