Hi all,
When i get my car back next month i will be pulling the turbo off and will be sold,along with braided oil and water lines.
I purchased an 0P6 housing and had it matched with my turbo.Then it was highflowed at Precision Turbos.
Highflow consists of machined front and rear housings(maximum)
Garrett Ball bearing cartridge.(will try and find the serial number for the cartridge)
It also comes with braided oil and water lines.
It has only been on the car for roughly 7000kms and is basically brand new.
I made 250.9rwkw at 16psi with this turbo.Has alot more in it and wouldnt be suprised if it would make 270-280 with a bit more boost.
The rear housing cost me $350
Braided lines $200
Highflowing of turbo $1550
Im asking $1650+post firm.
Old turbo off new turbo on.... big power!
NOW WITH FREE SILICONE INLET PIPE(second hand in excellent condition)
Bass Junky type.
Contact by PM.
CHEERS
https://www.sau.com.au/forums/topic/197284-highflowed-rb25vg30-bb-turbo/
  • 1 month later...
OK everyone i have finally got my car back so the turbo will be coming off the car.Those who sent me PMs for the turbo please get in contact with me before it goes to someone else.
dyno chart?
comes with reciepts/warranty?
direct bolt on for r33 gtst s1?
reason for selling?
Doesnt come with a warranty.But the thing is in great condition,i wouldnt be selling it if it wasnt.
Reason for selling is i have another turbo waiting to go in.And it will bolt on no probs comes with braided lines as described in first post.
is the just a standard r33 highflow? fitted it yet?
Sure is mate. Would have loved to buy NYTSKY's turbo its a very well spec'd hiflow but mine was too much of a good deal to pass up.
Its getting tuned today, I'll post up the results tonight after I've taken it for a drive.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
