Hey i need help with my r33 gtst
I bought it like a month ago. when i first bought it it was running smooth and good
the only problem it had was blocked radiator (i didnt figure it out for a little while)so it over heated if you gave it a bit but it was fine if you didnt give it any.
since then i got my mechanic (who is a really close mate of mine also) to give it a service, gear box fluid, diff fluid, engine oil and oil filter change radiator flush, with all the best raceing/synthectic fluids that are used in the evo 9s and 10s
artfter that It still had a miss at around 5,000 rpm wich got worse becuse i didnt get the spark plugs done stright away didnt realise how much platinum plugs were. (used to have a ford and there $2 a plug)
so last weekend i got off my ass and took my radtiator to nat rad and got them to clean the cores and replace the tanks in the radiator and i also did the spark plugs.
it ran fine for like a day maybe like 80% 90% pulling no over heating and still hasnt even on a hot day full giveing it to trying to make it over heat it was barely sitting on halfway in the hottest part of the day. then i realised i had filled the radiator with pure concentrate radiator fluid. so i flushed it again like yesterday or the day before and mixed it with water and i put it back in.
now its missing again and its getting worse :w00t: but its still not over heating:)
im thinking its a fuel pump or filter - my mate did test the fuel lines and filter he said seemd good ie not blocked. my mate thinks the fuel filter is good. he is just to busy to check the fuel filter amps and pressure, id test thes amps my self but my muilti meter broke. and i dont know how to or have the tools to test the fuel pressure.
the other thing i think it could be is and so does he is a cracked head/f**ked head (i hope not) i have checked the radiator for oil and the dipstick and oil filler cap/head for coolant and every thing seemd fine everthing where it should be. i havent done a compression test (havent been able to get the tools) and my mate has been to busy.
Is there any mechainics or someone who knows enough about skylines that i can get to just take a look for me and give me a defenate answer?
cause i don't wanna bother buying a new fuel pump if its a cracked head id rather save my money and get a rb26 front cut.
thanks in advance for any help or suggestions
https://www.sau.com.au/forums/topic/197295-r33-car-troubles/
  • Replies 41
Try Autotech in Fyshwick, Trojan in Mitchell or Gas Tune in Tuggeranong. I don't know much about these things. But it may be possible that it's your coilpacks.
thanks i didnt think about coil packs ill look into it
From what it sounds like, it is your coilpacks.
It's a very common problem with Skylines.
When they get hot it (such as your overheating problem) it expands the cracks in the coil packs that they get when they get old, and this causes the spark buildup in the coils to arc out and reduce the strength of the spark sent to the spark plugs. The amount of air going through the engine is enough to blow out the weakened spark hence you get your missfire above 5000rpm.
The temporary fix is to tape up your coil packs to try and close up the cracks and also to gap down your plugs to 0.8mm instead of the factory 1.1mm.
The real fix is a new set of coilpacks.
You've got like a 90% chance it will be coilpacks / spark plugs etc.
The other 10% chance would be stuff like fuel filter, fuel pump etc. What fuel are you using? Could also be fuel if you've put some dodgy stuff in. I only put BP Ultimate in mine.
Yes, but with the coilpacks, you will still have peace of mind that your coils arnt going to go wrong later and also you get a power increase from running them, not mention a more efficient engine. I would still get them even if they arnt the problem. My 3c.
PS I did this and it fixed my problem.
coils!!! or plug gap, gap should be .8 also you can use copper plugs instead of the $100 worth of platinum though I have never dont that myself but hey lots of people have and I can see a prob with stock use
Im sure that its a simple problem.
Use the "process of elimination" technique.
Buy a can of carbi cleaner from Repco for about $10.00
Check and clean your air flow meter first with the carbi cleaner, if the thin wire inside is caked in crap that will cause the computer to lean the engine out because it doesnt think its getting enough air flow, this will create a miss in the top end.
If that doesnt fix it run the engine and spray the carbi cleaner CAREFULLY* over the inlet manifold, if the revs pick up and the engine seems to run smoother then you have a blown inlet manifold gasket.
*The reason I say carefully is because carbi cleaner is highly flammable and you dont want the can blowing up in your hand :w00t:
Third, if the first steps dont work, find someone with an RB25DET that will lend you their Crank angle sensor, if you swap yours over for another one that you know works and it makes the engine smoother and more responsive then your CAS is on the way out.
Fourth - Check amps and pulse on the fuel pump, see if it is getting constant flow.
Fifth - Pull out your coil packs, clean them thouroughly, tape the plugs and tips up with decent masking tape and spray them with a heat proof enamel black paint, this should help to insulate them and stop any spark arcing out the side before it reaches your spark plugs.
If these steps dont work, I would do a compression test and see to see if your rings and valves are still ok.
Good luck :)
Nissan doesn't use a hot-wire air-mass meter, it uses a thin-film resistor meter. Personally, I have cleaned one that was covered in oil... but it did fail a month later. Some caution is required here.
I didnt say what kind of AFM it was I just said clean it... I know that it improves the response and smoothens the idle if you do it properly because I have done it on multiple RB25's and RB20's and it has worked everytime.
Thanks heaps guys ill try all these things and i only use that 98 octane fuel in this car i accedently put like $5 worth of that normal unleaded like 3 or 4 full tanks ago
Edited by R33Gtst Driver
platuim and iriudem plugs are good for lasting a long time ie in the back bank on a v6 camry where the plugs are hard to get too . from a performance view there not so good ive proved this many times in many cars racing speedway .i just use copper plugs in my skyline gapped down to .8 they have been in there 12 months and havent missed under load once so far . personally i would rather change copper plugs more often than use iruidems ect ect they just seem to fire better . my personal opinion is ngk plugs seem to work the best for me
cheers midlife crisis
+1, Agreed.
I would do a comp test before paying for coils.
You can do it your self with a compression testing tool from repco. (i think they are under $50)
If compression comes up good get coils.
ohh and i did have the computer checked for codes/errors and there was none on it
Agreed +2. Always just used copper and made stacks of power. I never really had any issues with them, and replaced them every 12 months or so :devil: I used them with splitfires though, which kicked ass.
Cheers
Anthony
I've also got a spare set of coilpacks at home, will have to check there condition, but happy to lend them to you to try out. Didn't really have a missing problem with them, apart from the occasional thing.
yeah that would be awsome if i could borrow/use them to test it out thanks heaps for all the help ppl i didnt expect this much help
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
