Before you flame about starting another 4WD prob thread I have read everything posted about it but still need help.
I have a 32 GTR and recently swapped my Tomei Reytek ecu for a D-Jetro PFC. The workshop had probs with tuning and eliminated lots of things including putting a new loom in.
Now my car HASNT got ABS as it was removed by previous owner. So the ABS light is always on since i put a nismo cluster in( still have to pull bulb out of this one as i didnt think of doing it before i put it in!) Now after the loom swap the 4WD light is also on constantly and front torque is NIL.
I just checked the error codes on the attessa ecu which came up with 2 flashes followed by 8... from what i found that means the Front left wheel sensor and ABS actuator motor is at fault.
I need to know if anyone else has removed their ABS from their 32/33 GTR and had to do something to the loom or something else in the system to eliminate this problem. Im guessing you have to something to trick the ecu that the ABS is still there or something.
...any info would be great!
https://www.sau.com.au/forums/topic/197343-another-4wdattessa-problem/
Despite keeping an eye out for this for years, I have never yet seen someone post a fix for this problem. no ABS = no ATTESSA.
Would be very interesting to compare your old (working) loom to a standard one.
Not correct...Ive removed the ABS and my ATTESSA is just fine. You must remove or unplug the ABS computer from under your rear parcel shelf for it to work properly.
Um my car has no abs module, has been removed, and the attessa definately works. Don't know what was done to it though, I do get the occasional 4wd error code, but only sometimes, and mostly in regards to the obviously missing abs module.
ill have to go and see if they still have my old loom at the workshop and see if something was done to the connections for the abs module.
I just dont get it as it was all working fine and never had problems until the loom was changed?? I dont think anything else was touched.
Where are these wheel sensors located? Maybe the one on the error code isnt plugged in.
Also which ecu under the parcel shelf is the abs? I can only see the Attessa and Hicas ones on mine.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
