Hi, was after a few ideas of things to check with my r33, the problem is soon as it starts boosting up it missfires to the point it just doesn't run, just coughs and splutters, this happens at about 4 psi, as soon as i back off runs perfect. Things i have tried to do to rectify the fault is change, ecu, spark plugs (all came out totally black), afm, cas, ignition relays checked, igniter (the earth seems good too, I asume its the one that goes under one of the coil holding frame bolts), JJR coils went in about a week before this happened aswell. I haven't yet pressurised the system to check for air leaks yet but all the cooler pipes seem well sealed.
cheers
Edited by SevenAngryPenguins
https://www.sau.com.au/forums/topic/197788-bad-missfire-under-boost-not-coils/
im having same problem aye, did urs start doing it suddenly? me mate put 95octane in his skyline and the thing just startn to get worse and worse missing, we changed the plugs and fuel filter but thinking mayb the injectors are screwed
dont know anyone else with a 33, but i chucked the old coils back in and the problem is still there
plugs are bcpr6es
hook it into the fuel rail if its a standard pump at idle it should see around 40psi if this is the case then its alright but under load if it doesnt make anymore than that I would think your fuel pump would be dead.
i put in a walbro a few months back and when it primes it sounds strong but i will still check it, how did you look at the gauge under load, i will have to get my little brother to sit on the engine while i boost down the road.
after lots of stuffing around ended up buying a supercheap aircompressor to check for boost leaks and found a massive one so problem solved!!
it was where my first pipe off the intercooler joined with the crossover pipe just after it goes though the engine bay wall if that makes sense, it was joined with a silicone joiner it appeared as if it was perfectly sealed but the clamp was done up right on the edge of the metal pipe inside with a bit of air pressure it leaked like a siv. I'm a bit annoyed at myself that I didn't check the hoses more closely the first second and third time that i did it. Would of saved alot of stuffing around.
a picture speaks a thousand words so they say
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
