I've got a 94 white one for sale have a look at my thred
yeah i did mate, you need a picture...i'm not looking at anything straight away as i don't have the funds and still have my other car...
i bought mine 3 months ago. i looked for smoke after 4 grand, kms leaks/ drips under engine/gearbox. paid 21.500 remember when buying a gtr tho there is maintenance maintenance and more maintenance :(
also how much would you expect a stocker r32 GTR to be going for? do you reckon i could pick one up for about 15k?
yes but thats definately towards the low side...
(like anything they vary according to cond etc)
normally around the 20k mark these days i think
If I were to purchase a 32 GTR, I wouldn't look at anything below $21k - $22k.
I'm not saying that there's no GTR under $20k that's good, but there's just a higher chance of them being in need of a rebuild soon, or things need replacing. If you find one for $17k that passes all the major $$ spending test, go right ahead and purchase it!
i bought mine recently for 20k, bargained down from 23k.
for a roadworthy it needed 1 new brake disk(replaced all 4)
and needs the engine mounts gearbox mounts and tailshaft center bearing are on the way out. but nothing to stress about just yet.
all up on the road i spent 21k on it, not including rego etc.
i guess thats not overly bad is it...i'm thinkin maybe i should save up a bit more money before i consider buying one...i was hoping i could get out of it for under $20k..but it looks like if i spend under 20 on the car..i'll be spending more on repairs...
My advice is buy private, all the 32 GTRs that I looked at in importers yards for comparison sake when buying mine where absolute crocks of shit. This was at various importer yards around Melbourne, someone like power play imports though usually import quality or reasonable nick cars (but also on the more pricey side of things as well).
http://www.powerplayimports.com/
So checkout the for sale section of this forum and carsales.com.au in the private seller section.
Cheers!
Gagz
PS...The R32 GTR for $27,000 about two fifths of the way down the page is one I was looking at when in the market, looks very neat and probably a pretty good price if you could get them down a grand or two. Good luck in the hunt >_<
http://www.powerplayimports.com/includes/c...php?make=Nissan
Edited by R31 Gagz
i have a mint r32 gtr which i brought over from japan and got a 2000 dollar service done by mercury motosports in brisbane. Body, mechanics, interior are all perfect. Not 1 dent. had a compression test and leakdown test with exactly the same on all 6 cyl. I wouldn't sell mine for less than 22k. Sure you can get them for 17k but parts are not cheap.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
