I've owned my car for exactly 5 months and 3 days (what? doesn't everyone keep count? :laugh:) and have mostly avoided catching the modding bug that everyone tells me I will get pulled into kicking and screaming. Now I want to bite the bullet and try for just one, and hopefully I won't go for more.
I want to get an LSD, specifically a 1.5 way, mainly because what I've been reading it will make the car grip to the road better, while not being a total pig to drive like a full 2 way. Not that it doesn't grip to the road already, I always think more is better and it seems rare for people to go for handling mods before power, and I do like being the non-comformist. But before I lay down the $1000 or so (which is my guess) I want some questions answered.
1. Does having a LSD make THAT much of a difference? I don't plan to make great times on a quarter mile, but I do like pinning my car around a corner and having it do exactly what I expect it to.
2. Kaaz, Cusco or other? Kaaz seems cheaper, but I'm told the Cusco will last longer and work better. For this reason I'm leaning towards Cusco, keep Japanese parts in my car ;). Is there any other brand I should be looking at?
3. Will I need to shorten the axles? One of the guys I work with said I would have to. Sounds like a pain lol
4. If the above answer is no, are they easy to change? If I rate changing a water pump, timing belt and radiator in a R31 Skyline on my driveway at home to be 4/10, what would you guess I would rate a LSD installation as? Another guy at work says a diff swap between two cars can be done in around 2 hours, that sounds right?
5. I plan on keeping my HICAS, will this make a difference to the choice I should make? I imagine not, but I could be mistaken.
Well I can't think of any more questions, any help on the subject would be greatly appreciated. :)
https://www.sau.com.au/forums/topic/198057-lsd-help/
I just put a Nismo 2way in my car yesterday, had the centre put in another housing with different gears by a pro. Was a little concerned when I realised I got a pair of right side halfshaft/flangeaxle thingos but after looking at the standard ones there was no way they would work. The Nismo came as basically a full rebuild kit, new bearings, seals, flanges, bolts etc.
Bit clunky but expected that, certainly a LOT more drive out of corners and a lot more predictable. I do have HICAS removed aswell so with the nice suspension and no computer steering for me it's a thoroughly enjoyable drive :laugh:
https://www.sau.com.au/forums/topic/198057-lsd-help/#findComment-3538072
1. not really except in tighter corners at full throttle - it really doesnt make much difference on street driving.
2. absolutely no idea. I'd be surprised if there was much difference
3. not if you get the right diff centre for your car. either way you only have to change half shafts not shorten the axles
5. no. but not sure why you would want to keep it - it really just causes problems.
https://www.sau.com.au/forums/topic/198057-lsd-help/#findComment-3540000
ok well i may be of a bit of help
i changed my diff last week with the help of my workmate, it was lucky he was there otherwise it would have taken me twice as long. im just a bit slow when it comes to doing things the first time. but i think if u buy one specifically for your car it should be a breeze a straight swap. just need a bit of elbow grease as all the bolts are very tight. i remember a workshop telling me it takes about 4 hrs or something.
also mite aswell take out hicas at the same time, lock bar is only $100 or so and u just need to take the plug out much easier than in the 32. not sure if that helps.
https://www.sau.com.au/forums/topic/198057-lsd-help/#findComment-3540169
but you need to be careful. If you are swapping the whole diff unit thats fine, its just bolt out and back in.
If you are just changing the diff centre you need to adjust it after you put the centre in - if you are not sure what you are doing get a diff shop to do it for you - incorrect backlash causes a nasty clunk and will ultimately kill your diff.
https://www.sau.com.au/forums/topic/198057-lsd-help/#findComment-3541959
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
