im not saying im super supreme (pun?) in anyway but i used to smash alot of stock r32 GTRs on a rollby but would get wasted off the line. but i would start catching up easily, but not enough to call it a victory. normally when i see a GTR i dont bother running off the line. maybe after i beat them real bad on the roll.
this was wen my car was at 250rwkw. so i cant wait to get my gt35 3.0L on the road =]
P.S i would like to explain again i dont think myself as uBur l33t. but just to give u an idea. wat do 32 gtrs output stock?
Edited by R34NRG
which drag strip in Melbourne does roll on starts?
I have certainly never heard of one, which begs the question, how and where is the 'slowest skyline driver' on the road smashing all these R32 GTR's on 'roll by'?
Ive got to be one of the slowest skyline drivers there are. i never ever speed and havnt even done my 1st burnout hahahah (tyres expensive :) )
2nd gear pulls alot harder in rwd mode than awd in my r32 gtr. Feels like an extra 2psi. Cheers!
oh yeah its only noticable in 1st and 2nd gear.. when boosting in 3rd gear it obviously doesn't put much to the front wheels while in awd.. there for making very very little diff.
Edited by gtrboosting
Mine was tested at AutoSalon in 2005.
604awkw on the Sat and 608rwkw on the Sun. Same dyno, just dropped the front shaft and that was it.
not quite, but that difference isnt anything to get major excited about.
It will be less, but not substantially at all.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
