hey all im in the process of picking a skyline and have found one that im pretty keen on, just wondering what you think its worth,
its an r32 with a rb25det that has recently been rebuilt with forged internals, it has a hks gt2540 turbo, fmic, pod, exhaust, spitfire coilpak, brass button clutch, 400hp fuel pump, 550cc injectors, apexi power fc, z32 afm, 3.5" xhaust, rebuilt gbox, brand new kaaz 2way lsd, gtr slotted rotors, all sorts of suspension work. they are asking 18g for it, do you think it is worth it? cheers
https://www.sau.com.au/forums/topic/198083-r32-rb25det/
kind of comes down to, do YOU think it is worth 18? if you like it and want it, pay it, if you dont think it is worth 18, then offer him less and be prepared to walk away with nothing.
hope its got receipts for everything
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3538163
is 18k the price his selling it for or did you get it down to 18k ?
if 18k is the price his selling it for try to bargain a few grand off ^_^ 15k would be good =]
but it sound like this guy has spend a sh*t load of money on this car..
as said eariler check the condition paint/clutch brakes etc
because for 18k i want to pay for a pretty decent car.
Goodluck mate
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3540417
hey mate,
I've got an rb25 in my r32 with almost the same mods as the person selling it....and take it from me...if he did all the work himself or since he's had the car , then ALOT of money has gone into the car. If the workmanship and the exterior of the car is in good nick - i'd say 18gs is a very fair price. The conversion alone is about 4g min, then add another 3g+ at least for the turbo setup. The motor and box have both been rebuilt, not to mention suspension and brakes. Thats a damn bargain price!!!
I know thats near impossible to get back any amount spent on any car - but 18gs for a car with that much mods is very decent providing the work is good and the car itself is in good nick.
F*kn good buy if u ask me -
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3542720
I am currently having the conversion done, the mechanic told me to allow $5k all up, but he's also rebuilding the RB25 with forged pistons etc. I already have all the bolt on mods, which 85% of them are being swapped over, the rest ae going to be modified to fit I believe.
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3543665
depending on who built the motor, what was done etc.
18k might be a reasonable price, it might not be.
The bottom end alone is worth 6-7k motor in/out.
If the body id clean, and it was a good build 18k would be reasonable to me.
It would be a very fast streeter... although the 2540 is a bit of rubbish turbo and i'd ensure i had 2k spare to change it to something a bit more useful
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3544047
well anyway i gought it this afternoon and have driven it round for the last four hours hahaha i got the priced nocked down a reasonable amount, it drives fines and goes hard, what kind of turbo do u suggest replacing the hks with, its currently making over 400rwhp
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3544606
I dont mean to be the bearer of bad news
But with a 2540, its not making 400rwhp.
Not even in the ballpark mate. A 2540 simply isnt capable of that.
You'll be lucky if its making 300-320rwhp at best.
https://www.sau.com.au/forums/topic/198083-r32-rb25det/#findComment-3544949
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
