so due to a defect i got new advan v103's, camber kits and a tyre saver wheel alignment. the car now feels very floaty at the steering wheel which im not liking. the car previously had a bit of camber and toe in the front, dont know the exact measurements, that gave a more direct handling feel and turnin was alot more crisp. it was great.
just wanted to know how many of you guys are running performance v's tyresaver alignments on your daily drivers? i want to get the most out of the tyres but at the same time get some decent handling out of them also. is it an either or scenario? they are asymetrical and stagered set so i cant rotate them which sucks.
cheers.
I'm in the same boat mate.
My front tyres are wasted on the inside of the tread, though the rest looks like new :D
Rears wear more evenly (though completely bald :) ).
Car is sitting on coilovers and has slightly negative camber, so i'm guessing that's shortening the life of the front tread.
My mate said a camber kit will solve it (but i'm guessing handling will be poorer).
What should i do? The car is only used for street, for now, so do i need a camber kit? Or should i just save the misery of sloppier turn-in and leave it?
I have the Whiteline adjustable camber bushes and adjust them all the way out for street (-1.5) and all the way out for track (-3), although I've got a slightly bent lower control arm at the moment which makes this a lie on one side until I get it fixed/replaced.
Omar, re your fronts, toe or camber can cause this. See if you can get the current settings for us. A wheel alignment shop might put it on the machine for a few $ and we can advise from there. That said, if your steering feels good then it's probably the camber which you can fix with adjustable camber bushes, providing you don't have too much to adjust out, or you can raise the car a little, or a combo of both.
Rears, there is a small amount of adjustment for camber standard but you've probably just lowered it too much so yeah, camber kit again to fix unless raising the car back up again.
I can see by eye all the wheels lean inwards slightly. The handling is crisp too, so i'm guessing its definitely camber. I'm going for a wheel alignment & balance soon, i'll ask for their opinion on the fronts.
I'd probably get the camber bushes if that was the solution, but saying that the nose sits quite low (the front lip might exaggerate that though) so raising a few cms wouldn't be a problem to save $$ on tyres.
I'll probably post again when i get more info and see what my options are.
Thanks Abo Bob.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
