I have been unable to find a lot of information about turbo repairs/rebuilds of HKS and garret items.
So far I know GCG can do it but I am in Melbourne and was wondering if there is anywhere local that can do it.
If you have had one repaired then please post up where you had it done and give the rough price you were charged.
Thanks
https://www.sau.com.au/forums/topic/198488-turbo-repair/
YEAH rotomaster via CREATD that way you get a good job or MTQ laverton.
GCG very good had them do a few for me over the years, KKK, TRUST and garrets all with no dramas. They have the best equipment in australia FACT.
https://www.sau.com.au/forums/topic/198488-turbo-repair/#findComment-3544562
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
