Try modicoat
http://modicoat.com/id41.htm
although it isn't a sticker, its a coating process. A mate of mine had his dash done in a coarse weave CF look and it was amazing! You would be very hard pressed to tell it from the real thing (texture excluded of course:D ) but the quality of the workmanship was very impressive.
Try modicoat
maybe a group buy would be in order here, planning on painting my dash and gearstick surround silver but that light brushed alloy looks pretty cool.
i was quoted bout $400 by a similar sort of place in victoria to do my wing blade.
In the end i got blitz to get me a proper one. looks cool has the n1 style lip (i think it is)
Try modicoat
Hello,
May i ask what car this is for??
It is true we will be making a R33 GTR carbon fibre blade. We are actually making the whole unit which allows the blade to be adjusted unlike others available.
Shane
This is for R33 GTR wing blade, I'm not actually looking for a carbon fibre wingblade, just the look alike stickers if its cheap.
Ive never really understood why people want the look of carbon with a sticker? It looks nothing like the real stuff and will peel of with the heat and hiidity. I just think if you have a GTR wing then why would you want some cheap sticker over it?? This is just my opinon and you may very well throw it out the window but i think your better of painting it black than putting some cheap fake carbon sticker on it.
that was my second option.......and it looks to be more sensible in the long run.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
