No, no mucking around, although to get it licensed the rego boys are going to want to see that you have updated to all the V8 gear - springs, brakes (all the brakes from master cyl to discs and callipers) diff, and....erm....thats about all I can think of. Remember that the XD did actually come with the 351 as optional (it wasn't deleted from the option list until mid XE)
The thing you have to ask yourself is, is it really worth it? The old XD-XF falcons really aren't worth a pinch of shit anymore, and its not worth pouring all your heart and soul into one unless you are looking at keeping it forever. And trust me, even with a V8 in it, unless you are drag racing it, it WILL be a dissapointment after a 200SX. Don't get me wrong, if you cut me I bleed blue ovals, but they are just a old falcon now, and they will never increase in value like the older ones did (unless it is an original ESP and you really don't want to upset the originality of one of those, and most of them had V8's in the already)
hey there,
me uncles gotta a XD falcon 6cyl the car is quite clean for its age and he wants to sell it to me and i wondering if a 351 would fit into it or is there some kinda mucking around
cheers
brakes are the same across the i6 v8 range with xd/e/f series front struts and springs are different (will need the v8 ones )
rear leafs are different rating as well you can get them reset at any decent spring works but most vehicle examination places wouldnt be able to tell the difference in rear springs
diff centre also different 8 3/4 lsd are relatively cheap from a wreckers
but your best option would be upgrading rear end to disk brake either 9 in lsd or an 8 3/4 lsd
i looked into doing this many years ago and was told that brakes and suspension was the same for 6 or 8
But this isnt the place to be asking, there are plenty of ford forums with more accurate information.
Edited by W0rp3D
yeah as has been said putting a 351 into a xd is rather easy. if it was an xf then you would be in for a bit of a shit fight. i would also agree with going for the fuel injected v8 out of a later model. rather cheap to buy and much nicer motor, or a turbo motor from an xf or even a just 4.0L 6 out of a later model falcon. as for performance, it would go ok because even though they are a massive car they are rather light (somewhere round 1300kg, depending on options). so with a decent motor they can get up and boogey. but that said it won't corner like a skyline. it will still handle like a xd falcon.
yeah buy a windsor, i build a few clevos but they are tight in the bay.... fit this to the windsor while your at it.
http://cgi.ebay.com/ebaymotors/Ford-Mustan...sspagenameZWDVW
this is my slug.
http://s188.photobucket.com/albums/z46/URA...rent=v8ltd1.flv
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
