Hey all sure most of you wont care but here she is....
Sold my silver r33 series 2 about a week ago and have just taken the keys to my new car.
Its a 1995 GTR R33
Heres a couple pics not very good yet
Just about stick as a rock except, triple plate clutch, trust FMIC and N1 turbos
https://www.sau.com.au/forums/topic/199156-my-new-car/
  • Replies 64
Posted Images
yeah, agreed , the purple looks brilliant mate!
even the RB26 is purple! nICE!
Yer thanks guys!!! just needs a cut and polish to get a few little scratches out etc...
But yer its my daily driver so hope someone sees me around!!!!
And PK if you read this i need some new stickers!
https://www.sau.com.au/forums/topic/199156-my-new-car/#findComment-3552202
Just about stock as a rock except, triple plate clutch, trust FMIC and N1 turbos
Looks like you got some more mods than just those. I'm guessing an oil catch can plus others judging by the engine bay.
https://www.sau.com.au/forums/topic/199156-my-new-car/#findComment-3553160
oh yer and a catch can! lol....
ummm cant reali see to much else in there but hey i dunno what im looking at reali! lol
but yer loving it so far!
https://www.sau.com.au/forums/topic/199156-my-new-car/#findComment-3553407
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
