the top intercooler pipe that runs past the radiator seems to get pretty hot. but then everything in the engine bay gets pretty hot. i never checked, but i assume even the stock coldside pipe would have warmed up quite a bit under there.
so anyone who has bothered to heat wrap, or ceramic coat the pipe....did it make any difference?
is it worth doing? or does the air pass through there so fast that its not affected?
what about the guys with the stock cooler piping. after driving, does your cold side pipe feel hot?
Edited by Munkyb0y
Not a brilliant pic, but gives an idea of my efforts.
Running an inlet temp probe just prior to the throttle, I found inlet temps skyrocketed with slow speed, low load, stop start driving. The exit air temp from the radiator is 80 degrees +, and heat transfer through those alloy pipes is very rapid. Basically you'd have to expect degraded engine performance and an increased tendency to knock with higher inlet temps.
I changed to a custom fabricated steel pipe, HPC coated, then used a ceramic wool and covered with sticky backed refrigeration tape.
Result was much reduced heat soak effect IN THOSE CONDITIONS nominated.
Running at higher speeds (80km/h and above) + loads the differential effect was much less pronounced. Not an indicator of anything other than the higher mass flow of air being less affected by the radiator discharge in those conditions.
so the trick is to not slow down and always have good airflow through the engine bay.... otherwise I need to wrap my nicely polished IC piping...
"Excuse me sir do you have any reason for speeding back there", "yes well I didn't want my inlet temp to get any higher as it lessens the performance of the engine..."
hehehehe
what actual inlet temps did you see during the low speed, traffic driving? and what temps at 80kph+?
how do these compare to the piping that's not heat soaked by radiator air?
there's also that reflective stick on stuff. it's supposed to deflect alot of heat.
this is another good idea. http://www.skylinesaustralia.com/forums/in...t&id=133021
Edited by Munkyb0y
Thanks for that link, i have been looking for something like that for a while, plazmaman sells piping kits with there top pipe like that http://www.plazmaman.com/shop/index.php?ac...m&itemId=21
or...or... think about this.
buy a GReddy intake plenum.
now thats using your noggin'
Im trying to keep my car as legal as possible when you pop the bonnet and the greddy inlet would be another inlet mod.
or ... or.... buy a Veyron!! :D
Not everyone has a cool $1000 lying around just to get slightly better intake temps and response.
Back on topic - I wrapped mine but can't say it made any noticable difference. However, I haven't actually shielded my pod yet, naughty naughty!
Nice work dale, makes me want to eat some garlic bread, LOL. PS I think with that insulation the HPC would be a bit of a waste of money, not much would be getting through the rest.
Yeah, it does look a bit like wrapped garlic bread :D HPC probably was a bit over the top but I decided to give it the best chance of success. Then the cast alloy pipe is affected by heat radiating from the manifold and top of the engine.
Correct to some extent. It's also about the mass flow through the inlet tract, with a reasonable velocity preventing the heat penetrating and affecting the air within.
I'd have to dig out some old notes I made while testing, but basically I was achieving Summertime inlet temps of 80+ degrees in stop/start traffic, idling at lights etc.
With the piping setup as pictured, it came down to ~ 60 degrees at an ambient 35-38 degrees.
Clearing the traffic light runs, with about 3km of constant running ~ 80km/h and a bit of throttle, it would come down to somewhere around 50 degrees or slightly under.
I ran some temp probes at different points under the bonnet, and on hot days the heat buildup under bonnet is significant. Those 270 degree pipe bends aren't a bad idea but you'll still get radiated heat affecting the air within them too.
I take it that the reflective stick on stuff is the tape you're looking at in my photo? It is basically a heavy grade alfoil with sticky back. Good, but I wouldn't use it by itself as a long term solution.
The Greddy style manifold may offer significant improvement over stock RB25 if trying to reduce heat soak.
out of info, but that's my experience and opinion.
cheers
Dale
Not sure but was there a mention of CAI in your setup dale?? Or if any sort of coating on exhaust housing and or manifold, of which both should minimise heat again to a certain extent its all about reducing the temps at the start as well more so..
from what i've been able to find, the air apparently travels through the piping at such a high speed (10's of metres per second) that the effects of a hot pipe are minimal.
the temps going in, as stated above ^, have a greater effect.
I just wrapped mine with heat wrap, same as the exhaust wrap stuff. Dale seems to have proven it but there is not doubt that thin Alum. pipe will conduct heat well when there is little airflow.
was there a noticeable improvement?
there's also this stuff, but it's gold :(
http://www.mmsport.com.au/productview.php?...d=Heat_Products
Edited by Munkyb0y
Yes, all true.
The manifold and turbo is all heat shielded.
The big silver box in my pic is a sealed pod enclosure with silver faced neoprene for insulation, and a direct external air feed. I couldn't afford/justify the down time or expense of removing and sending the manifold or turbine + dump for HPC coating. It was as far as I was prepared to go, but I proved to myself the value of the changes through the inlet temp probe.
not really...but it must with help with heat soak...but then again I dont drive my car that much in the heat or at the lights.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
