Z32 and Q45 dont cut it, running a PFC in my RB25DET S1
Need larger, anyone tried cutting the sensor out the Z32 or Q45 and installing it into a larger diameter pipe? thinking of cutting out the sensor bar and installing it into my 100mm intake pipe as well as putting a smaller 40mm ID lexan tube round the sensor about 40mm long to stop air swirl or cross flow effecting it.
Just wondering if anyones tired anything like this? thought of changing to a GTR ecu but ive just got poncams for the VVT, dont want to kill that now.
Edited by Rezlo
https://www.sau.com.au/forums/topic/199290-larger-maf/
You can put the AFM in the intercooler pipe. This compresses the map so you can read a bit higher, but it's a little harder to tune and you have to retune for EVERY new mod. You can always use a Ford AFM from a newer lightening.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3553337
Why? If a Q45 AFM is too small, why are you running a PFC at this stage of tune?
I use my car to demonstrate to a lot of customers the ease of the PFC, I thought of going with a GTR PFC but ive got a set of poncams which are obviously design for the VVT to be active, which I would like to retain.
Im not a fan of blow threw, Will look at the new lighting maf,
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554011
Humm, Are you guys that use Q45's using the newer year Q45 (pink sticker 31U00 E60 ) or older Q45 (yellow sticker 61U00 / P60) MAF's? All the ones I have here are the slightly older yellow sticker ones... which seem to be only hold slightly more than the Z32's
Edited by Rezlo
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554103
Im making enough that the Z32 maxed at 1.4bar and the Q45 maxed at 1.5bar, I used 3 different Z32's and 4 different Q45's all 7 maxed within .1bar of each other. I have double and tripple checked, there are no leaks what so ever anywhere and ive changed my intake setup 3-4 times over the last 2 years also with no change in being able to run more boost before it max's.
If it wasnt for the Poncams/vvt i would rip it out and use a D-jet R33 PFC, I have had similar results using Z32's and Q45's on all the SR20's I have done as well, all come 320-350wkw they are right up in voltage, using all different set up's and hosts of different intake lenghts, air filters ectr, how you guys get so many WKW out of them/what im doing wrong is beyond me, but its repeatable threw all the vehicles I have done over the last 7-8 years...
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554148
when is the afm maxing out? if its up in the top rev range then its no different to map sensor style setup
with a map sensor style setup once you reach target boost load never increases so you run across the horizontal axis on the map
the same thing will happen when the afm maxes out, it will hit its ceiling limit and wont increase - so youll run across the horizontal axis on the map
in both cases when load stops increased more air is coming into the engine so you are no better or worse off
the only time i wouldnt think this would be a good idea was if you were maxing the afm at say 3000rpm
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554456
go gtr ecu with twin afms.
just get two $30 chiptorque shiftlights, they are small, throw away the light but use the output to drive a relay to turn the vct solenoid on at xxxx rpm then use the second one to turn on a second relay (normally closed here) to open circuit the first relay and the vct solenoid will turn off.
otherwise im sure jaycar do a freqency switch, unsure if it has two set points but, thats why i suggested the above or similar.
vct is the easiest part to solve really.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554486
correct if boost increases, so will map sensor voltage but if the car is setup for 22 psi once the map sensor see's 22psi it will be lets say 3.8v
this is then used to give the ecu its LOAD value and place it on the load axis - as the boost controller is set to control boost to 22psi - boost won't change until gearchange - therefor the map sensor value wouldnt change
when the afm maxes out say at 5000rpm at 22psi boost will still be 22psi but more air will be coming into the system
the afm will ceiling at 5.0v and show no more load - so the same result, LOAD on the ECU level wont increase and it will run across the last axis used
so in either way you have to just juggle the afr's and ign timing on the last row it runs across and you loose some map points
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554488
haha thats a great idea
good thinkin 99
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554491
yeah but you have to comprimise i did my first 180 that way, HKS 3037 with std s13 afm.... the flatline needs to be power robbing rich for everything but full boost full load. It works but its messy and far from ideal.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554536
yeah i understand you can dial in any map snsor with offset and pim scale etc
but if you have the stock apexi map sensor and you run say 15psi it could be say 4.2v
if you run say a 3bar GM map sensor and you run say 15psi it could be say 2.6v
once 15psi is in the manifild i dont see how pim1 voltage will increase any more
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554591
the problem with running it maxed out is you have to compromise run it rich for the max boost you want to run, so any less boost that is not down on a lower load point is filthy rich.
the second bigger problem is timing, because you have to retard for more boost, you have to do the same thing, set a low enough figure on the last load cells for the highest boost you want to run, but have boost below that amount and it will be to retarded until it drops low enough to access a lower load point.
i have been up this alley recently with a different vehicle and its the shittest setup ever and you risk your engine.
the only other way is to setup an air flow meter bypass, but that is still dodgy in my books, easier if you had a twin throttle bodied engine but.
this is the biggest problem with air flow meters, once you make serious power it can be a pain in the neck and easier to have gone a speed density system to begin with.
the only bigger maf is know of that will work is the ford lightning 90mm air flow meter, old mate in the us is using one and its only at 4.7V at 490rwhp, so its a real bad boy!!!
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554645
Yes this is complex, but honestly I cant see why the following is such a bad idea:
Cut the sensor bar out of a Z32 or Q45 (ill use a Q45 because I have loads of them laying around) and make a mounting flange, and mount it into the 100mm intake, the effective area of a 80mm ID Q45 is 5024mm2 going to 100mm would make it 7850mm2, also what would be a pretty nifty idea would be to use a short 40mm length of 40mm ID lexan thin wall tube and actualy mount it around the sensor bar so that the air flow threw the sensor is straight and undisturbed. this will give you a MAF capable of a lot more CFM before maxing, and with the PFC one could just re-scale it as needed.
Can anyone tell me why the above wouldnt work as a cheap and easy (well easy for me) method to solve maxing Z32 or Q45's
? another nice thing is it will have near no restriction.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554663
Yeah.
But. The AFM still reads air going past it. RB25 AFMs are 80mm too and mine is maxxed with a std Turbo.
The Gain with Z32 or Q45 is that they are designed for bigger motors and are calibrated as such.
a 4.5L V8 will suck more air than a 2.5L 6 so its calibrated that way.
So as far as I can see (and correct me if im wrong) You could put a Q45 AFM in 200mm Pipe and it would still read the same.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554674
Yeah.
No, the air flow speed over the sensor would be slower in 100mm than 80mm, with hotwire the reduced speed would = a reduced temprature on the heated sensor = lower voltage.
https://www.sau.com.au/forums/topic/199290-larger-maf/#findComment-3554681
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
