Low end increases? Keep your stock cams then.
For mid-range increases, then 264 degree cams are the go.
The reason people talk about TOMEI poncams is because they are a direct fit (~9.1mm lift).
The HKS cams which are a direct fit are only 8.4mm lift, so most people just go for the TOMEI cams.
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553570
If you want to focus on low-mid range power i would try the new Tomei "Type R" poncams for GTR. I think they are around 252 duration, and very effective for low-mid range. Cam gears will also help bring boost/powerband earlier. I wouldnt do cams without out the wheels. I have Tomei type B poncams in mine.
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553593
The HKS cams dont have enough lift in my opinion. You would get better results with the Tomei's. Better to spend the money right the first time. I think its been proven many times that Tomei Poncams are the best cam solution for GTR. They run the most lift of all the "drop-in" type cams which i think is important when choosing cams. More lift equals more air to breathe.
If you just wanna shift your powerband earlier, get a set of cam wheels fitted and dialled in. This will bring power on earlier, but at the expense of top end power dropping off earlier.
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553602
so keep the standered cams and get some cam wheels?
but surely HKS is still better than standered?
Cos i doubt ill ever spend 1000 on poncams
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553606
Yeah, HKS would be better than standard of course. But the Tomei's even better :D ..Tomei's would give a greater peak power/torque throughout the rev-range compared to a similar duration HKS cam i think. (Which is the reason most do a cam upgrade)
What are the specs of the HKS cams you were looking at? Durations/lift specs?
Think about what your end result/goal of your car is, and whats gonna work better for you in the long run. If your on a tight budget, then there may be other areas of your car you can upgrade and get better value for $$$ per KW
Someone on the forum may have used the same HKS cams in their car, hopefully they will find this post and give an opinion from experience
Edited by Blue_GTR
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553614
HKS DURALUMIN+ Ni PLATING cam gears. item number are.. 22004-AN002 RB exhaust, 22004-AN002 RB intake
Thats all i know about them and ive tried searching cant find anything... hmmmm can anyone shed some light on them??
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553618
its just i can get a set of HKS cheap lik 499 new
Brand new Intake & Exhaust side HKS cams for $499? I don't think so.
For your application the Tomei Type B Poncams are the best choice.
The Tomei Type B package that includes Tomei Duralumin cam gears is a very good option
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553652
We don't run any cams in RB26's without valve spring upgrades. The standard valve seat pressure is abismal, so the rule of thumb steps we use are;
Up to 9 mm lift = shim the standard valve springs
9 mm to 10 mm = Performance Springs, best value for money and shimmable to achieve the seat pressure desired
Over 10 mm = Jun valve springs, simply the best. Keep in mind the MINOR releaving of the head to clear the cam lobes (not a biggy, but necessary)
All of the above can be accomplished without removing the cylinder head ie; done it situ in the engine bay.
You want more low down performance, TURN UP THE BOOST, nothing else works as well and is that simple.
Happy New Year
Gary
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553657
on its from a mate whos not using them now.
let me guess oncams over a grand?
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553663
Happy New Year
Gary
cheers for that...
you wouldnt know the specs of the above mentioned HKS cams?
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553666
Dont Forget the new GREDDY easy cams, direct fit, supplied as a matched pair with all the centreline checked so that they (in most cases dont need dialing in) , cheap and all have new profiles ground off a brand new machine. 256 9.1mm lift or 264 9.1mm lift available.
http://www.trust-power.com/spec_swf/05engi...mshaft_easy.swf
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553678
I am on a tightish budget...
my cars stockish.. has a trust intercooler, n1 turbos and triple plate clutch...
Buying
Turbo back exhaust (unsure what diamater yet or twin/single. ideas?)
Power FC and controller
Boost controller (the add on one to the power fc)
Apexi intake...
then i have around 500 left and thats what ive talked my mate down to wid the cams..... 500 better spent any where else then??
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553679
Buying
Apexi intake...
TUNE
Cheers
Gary
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553685
^^^ good call, with your setup ADz you should see reasonable power as it is with a decent tune.
oh hey ive budgeted for a tune, sorry didnt put that.. still have around 500 left over... cam gears worth it on standered cams?
what kws est would u think that set up could make>?
Edited by Adz2332
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553705
Hi there, just a dumb question if it hasn't already been asked, $499 quoted is for HKS cams or HKS cam gears only?
Cheers GW
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553709
Cheers GW
na na not from a shop!!! mate has them selling cheap to me! mates rates lol and no cam gears
https://www.sau.com.au/forums/topic/199301-sorted/#findComment-3553711
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
