for the tech boys :D
i will be using my hks actuator to control my boost setting at what ever the spring rate is set to which i think is 12-13 psi.
just want to know what size boost jets should i run to achieve 15 psi.
for the r33 gtst
thanks guys.
Edited by R33GOD
The jets fit in the end of the wastegate vacuum hoses. These attach to the fittings on the intake pipe before the rubber intake hose that feeds each throttle body.
boost jets....
if you guys go to the 300zx forum they clearly tell you what they are and how to install them.
my dad done it on his 300zx. stock setup. runs 12 psi nicely with no boost spike
boost jets....
Boost controller or boost jets:
Boost controllers and boost jets are the recommended way to increasing your boost pressure. Adding a boost controller essentially tricks your waste gates, waste gates vent boost allowing the car to just run at 8 psi. The boost controller or boost jets trick the waste gates into thinking that there is less boost than there really is meaning you will have a quicker spool up time and a large increase in total boost pressure. Boost pressure equals power. Running higher boost pressure is only capable after an ECU upgrade. Investing in a turbo timer is also a good idea when running higher than stock boost, as a turbo timer will help cool your turbos when its time to shut down.
i'm still confused
WOW, upping the boost to 12psi will help my turbo spool quicker........ :D
And i need an ecu upgrade to run higher boost.... :devil:
The only thing i can think a boost jet is would maybe be a tube of something with a smaller hole in the centre so it lets less air through to the wastegate.
Just get a boost controller and do it properly from the start.
yes i mean an actuator, most of the ones i have seen are adjustable so it should do a fair bit of boost, with one of these i dont understand why you need the extra bits.
You hav'nt really explained your self very well, got any pics of what you are chasing?
reason why i dont want to depend just on the actuator is because iv'e heard from a few people so far that when you run them on what there set from factory (12-13psi) they work better than a boost controller but when you try to increase the boost pressure through the rod boost will come on abit slower and will tend to spike.
no pics at this stage mate
Just so I understand, boost jet is a fancy name for a non-adjustable bleeder type boost controller, right?
Never heard it called that before. Anyhow, bleeder valves are generally the worst type of boost controller.
If you want to do it on the cheap, you'd be better off installing a precision spherical coil actuated pressure regulater install, which is more commonly referred to as a ball and spring boost controller. :D There's a great one on ebay for about $35, search for 'Turbotech'.
  R33GOD said:
people that mock this way of boosting a car dont know about this method. need some tech guys who know what there talking about and that have played around with these jets.
rofl :D
I wouldn't think you'll find a "tech guy" as you mention it, using one of these "boost jets" on a skyline for obvious reasons. A $20 bleeder would prolly be a better option
Note my use of quotation marks for "boost jet", much like "Santa Clause" "Easter bunny" and of course "hot lesbian"
I wish you luck
Edited by GeeTR
forget the term boost jet and call it what it actually is. A "Restrictor"
its a small piece of steel tube that is fittted snuggly inside the actuator supply line from the manifold.
it has a smaller hole in the middle approx 2.5 - 3mm compared to the 6mm rubber line.
im running one in conjunction with my PFCBC and a 18psi actuator and i have no issues controlling boost up to 27psi.
ramps onto boost hard, and then stays within 1psi to redline.
and just to clarify an earlier remark in regards to increasing boost can make it come on sooner.
if your target level is close or just past your actuator tension, then your internal gate flap will allready be opening before you reach your target boost as to control the clime in pressure. If you were to run a heavier actuator and run higher boost then the flap will stay completely shut for longer causing it to ramp up harder and earlier.
not 1000rpm sooner but certainly 100 - 300rpm sooner.
FYI.... Sydneykid had posted this earlier on a different thread [http://www.skylinesaustralia.com/forums/Jaycar-Boost-Fuel-Contro-t61207.html&st=20], may be of assistance?
" 30 Jan 2005, 10:59 AM Post #37
I thought everyone with an RB25DET knew how to do it. You just disconnect the solenoid (vacuum, not electricaly), connect the boost feed directly to the wastegate and use the (standard) restrictor to bypass the desired amount back into the turbo inlet. The standard byspass hole of 1.25 mm bypasses enough air flow for 0.5 bar. Tools needed = one pair of pliers and 10 minutes.
PS; If you want more boost you can drill out the bypass, 1.5 mm = more boost (around 0.7 bar) 1.75mm = a bit more (around 1.0 bar). But the Jaycar Boost Controller needs the bypass to relieve trapped pressure between the solenoid and the wastegate actuator. So I don't want to redrill the restrictor only have to solder it back up again."
"This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses. Disconnect the two vaccum hoses from the solenoid. Then connect the boost feed (from the cross over pipe on the left of the picture) to a the standard T piece. Connect one side of the T piece directly to the wastegate actuator (on the right of the picture). The remaing connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting). Make sure to put the the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar."
If I could work out how to insert the photo I would have soz lol... noob here... hope it helps whoever :-)
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
