  • Replies 3.9k
Posted Images
As usual i dont take any notice of pace until Q2. Everything up until then is just strategy!
I agree,
but this has to be one of the closest practice sessions so far this year with less than a second covering the top 12.
force india must be happy so far this weekend. 2 cars in the top 10 in second practice
I would expect BMW to be closer to the front come qualifying
Looking good. Great to see Webber ahead of Trulli. Great to see Alonso up the front, and great to see McLaren could only get 5 & 6. LOL, the more they stuff around in the pack the more credence the stories about Alonso's contribution to the McLaren team. Especially with Alonso an Renault getting quicker.
Will be interesting to see what happens in the race with fuelling
wow, Renault DID make gains, well done Piquet and especially FA
BMW should have done a lot better than what the did, Kubica once again has no juice in the tank
I get the impression Hammo still cant handle his own car setup at all. He seems to be the only car to consistantly slide turn 7 and 10 and the ITV idiots for one reason or another praise his ability to hold the oversteer.
i got money on you kimi, dont let alonso push you around into the first turn
Alonso must've been right on it to get that kinda time...
Be good for the Spanish to see their hometown hero get on the front row..
Again, reiterating what most others are saying... Louise ftl... Useless without input from an experienced teammate..
Heidfeld should be good here, esp if the BMW's can get a good lick of speed on the main straight...
Hopefully RBR come up with the goods, and hopefully the Newey penned car is slippery in a straight line...
i think for every year fernando is in formula 1, his self confessed omniscient presence must have some kind of performance gain that doubles every year... Renault are just now reaping those rewards
all very easliy explained you see
Big fat loads of bollocks to you Ivan, lol!
yeah i remember, hes worth 0.6 seconds to the team...so in reality, if we added up all the years hes been competing, he should be able to make any car go 4 seconds faster!
Shit, even force India could win a race with him at the wheel!
Edited by m3gtr
Ive been thinking about this for half an hour now and i still dont get it...
Either their RIDICULOUSLY light for the start or they found this time in spite of the fact it has taken teams years to bridge these gaps...years in comparison to Renault finding that time in 2 frickin weeks...
I smell mass damper bullshit again!
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
