After driving Xboy's GTR, the turbines kick in at around 3500rpm, and boy do they kick in :) however until you get there it's a little dead. So would it be possible to put a third small turbo or even supercharger to cover say 1500-3000rpm or so?
I've driven the Liberty B4 and the power comes on rather early <2000rpm with the first turbine, then the second at around 4000rpm.
My extreamly limited knowledge of car mechanics would say why not put a third smaller turbo on the GTR, I've heard of supercharged twin turbos on small cc engines, why not on a larger engine or even a tripple turbo? I am assuming that this concept is either ridiculas for some reason otherwise somone else would have done it?
well i dont' know if it really is possible .. i'd say no .. but i'm no expert .. if u wanted it to kick in earlier i'd say the choice of the turbos are more important along with the tune ... i'm sure the turbos can reach boost earlier .. say 2.5krpm with the right settings ..
It would be a bitch to design as the small turbo would have to ajoin the plenum of the 2 big turbos. PLus the constraints of the room in the engine bay, plus pipin to intercooler, i doubt in practice it would ever work, however in theory it would.
Anymore questions
The GTR's aren't sequential.. so you're probably out of luck with what you suggest.. maybe more appropriate on a TT Supra where its a sequential setup.
See the Liverty is sequential.. so its been designed as a refined daily driver and just driving around on boost most of the time with power always ontap across the range via two smaller turbos.
What you're experiencing on the GTR isn't a "gap" in the range, its just how its engineered as a non-sequential twin turbo setup.. to give full kick when you really need it - that is mid to high range power.
I think there was a concept RB26DETT motor with a supercharger (its posted on here somewhere).. it wasn't in a car for some reason.. I think it had to do with basically just fitting - as the supercharger pushed the width of the engine out too far to fit in an engine bay. Anybody correct me as to why they couldn't get it in a car??
NASA developed a 4million horsepower engine with one VERY large turbo feeding into another large single turbo, then that feeds 2 x smaller twin turbos (all in sequence) and makes 400psi boost. They now use these engines in their planes that fly on the edge of the atmosphere or statosphere. The turbos are 4 times the size of the engine itself, which is no bigger than a 4 cyl engine....
Also, I can't remember who, someone on here will, but a rally car driver had a Delta S4 which was supercharged and turbocharged. Best of both worlds....
My 25 to 30cents worth
Guest MFX_R33
Twin charging is alot of stuffing around for very little gain. If you are getting good boost by 3000rpm that is fine. All you need to do is to adjust your driving style. With a redline of 8000 (you could even push further than that), you have a rev range of 5000rpm. That is quite a good useable rev range for most driving.
Jeff.
Yes it is a bit of a dreamer idea. but thought I'd check it out. Looks like the concept is fine, and a suprecharger would be the way to go, if it would fit :(
Don't mind having the power up in the higher rev range, but would like a bit more down low for just "normal" driving. Would be ideal as you could then have nice progressive power with the option to give it boot when you want to really bring it on :D
Guest INASNT
big boats use the same system feeding compressed air from 1 turbo into another in another etc
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
