Hi,
I bought an Earls 13 row (wide type) oil cooler core for my R32 gtst with built, single turboed RB26 in it. After making some modifications to the intercooler piping, i can now fit a 16 or 19 row core in the drivers side inner guard.
My question is; although ill probably do minimal track/drag strip work, should i fit the biggest possible cooler i can in there? I suspect the answer is yes, but just thought id ask first.
Oh, im not using a thermostat either. The dimensions for the 13 row are (W)225x(T)50x(H)100mm. The 16 row is 25mm higher, and the 19 row is 25mm higher again.
Thanks for any help,
Shaun.
is it a street car as well? If so, with a larger core, you'd be wise to fit a thermostat inline.
It would pay to fit a larger core, you dont have to go too crazy, bu something bigger then you have now, aided with ducting would be great
I've talked to a few people about this as well, and surprisingly, bigger is not always better and where you place the cooler is important too.
I believe any size would decrease oil temps, but also make sure you mount it "BEHIND" the radiator.
You gotta keep in mind, you want your oil above 100 degrees, and if you are driving it day-to-day on the road, with a large oil cooler, mounted right at the front, the oil will be cooled with air in the 20-30 degree range, possibly making the oil too cold to do it's work.
Just to give you an idea, I'm driving a R33 turbo, no cooler at all, and it would see the mountains (Mt nebo) and QLD raceway at least once a month. with no overheating probs what so ever. But keep in mind I will be running some upgrades very soon, so will seriously consider an oil cooler upgrade soonish.
sorry for the long post.
run the bigger cooler. and don't run it anywhere near the radiator. far better to have it housed in either side duct. thermostat is a good idea, but if you don't want to add one just monitor temps and if you find it wont get up to temp then just use a piece of perspex of aluminium sheet and cover part of the core during colder weather. on the street you don't really want temps over 100C for a skyline. 80-90 is fine running temp.
I think youre a wise man Beer Barron. Thats exactly what i was thinking of doing in cooler weather. The GTR engine uses the heat in the water to heat up the oil on cold start doesnt it? For this reason, it was recommended i dont run a thermostat.
Anyway, ill get the bigger one.
Shaun.
yeah, there is a heat exchanger in the oil filter mount assembly that puts heat from the coolant into the oil to help bring it up to 80C. go big, on hot days and track days you will need it. when you don't, just use the little alloy shield to block airflow to all or part of the core. :)
I have never had too cold oil anywhere in Australia, so I have never ever considered a thermostat.
Cheers
Gary
you dont live in the adelaide hills... some nights it gets wayyy chilly, great turbo weather but my oil temps struggled to get over 60 degrees, i covered the core with cardboard and they went up to 90... til i decided to fit a thermostat. couldnt be stuffed with cardboard
Mt Kosciusku, minus 5 degrees often, every winter, every year for 10 years, all sorts of cars, all with oil coolers. Never needed a thermostat in any of them. How about a rally car on Mt. Canobolas in winter, now that's cold.
Regardless, 60 degrees is not a problem. Plus I assume that you are measuring the temperature post oil cooler, so the "operating" oil temp is more like 80 degrees anyway.
Cheers
Gary
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
