Hi All,
I just got about 10 seagull turds on my car at work, washed it off within 2 hours but the damage was already done. I used a pressure washer to clean all the crap off but the 'residue' left over is stuck on the paint! Colour is a dark blue and had a full respray about 1 month ago.. :)
What's the best way to remove the residue/stains? Any help appreciated
Cheers,
https://www.sau.com.au/forums/topic/199860-bird-sht/
With WD-40, the paint won't sqeak as it moves around!! <<WTF?
LOL... i accidently got some silicon on my car last week and i didn't know what to use to get it off and all i had was some petrol and a can of wd40..used the wd40 and worked a treat!!
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3559742
bah try hot water mix with some terps but do it quick or else eat the paint i think and have hose with ya as well when ya do it lol should take it off quick if not wipe it down as well , a car detailing friend told me to do that but not reccomended to do i never tried it my self maybe for you should try it ,
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3562933
The 'residue' doesn't come off with a pressure washer or sponge & detergent but it feels like it is sitting on the paint, not eating through.. i thought bug & tar remover was very harsh on the paint??
claybar
will remove anything sitting on the paint
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3568202
So WD-40 is like a cure all? Like Windex in My Big Fat Greek Wedding? Spilt silicon, get WD-40, have a cold, get WD-40, get hit by a car, get WD-40. Its a mirricle formular!!
And thats the end of my randomness for today!
seriously try windex as i find it work really well to get bird crap off the paint
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3568208
Claybar is good but I just didnt wanna throw the idea around to someone who has never used it. If it scratches the paint I dont want to be reponsible for fixing it!
Bug & Tar remover isnt harsh on the paint. A good polish after ad you'll be sweet...
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3571299
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
