Hey guys, im thinking about doing a project car that alot of poeple are probably gonna hate me for, but i dont care as its my money and i can do what i want with it.
Im looking for ideas and sugestions on what i can and cant do, ways things could be done and just what would be the better and easier way. Please if you have nothing nice to say dont say it at all, or if you have to, pm me. . cheers
Ok so this is what im thinking. . I want a big car so i can fit more than a shoe box in, something that i can drop nice and low and give a VIP look to it, something that can tow a trailer like a boat or a 6x4 and still be good to just cruise around in, AND has decent power . . nothing crazy . . . yet lol
Im thinking about Doing a VT-VX Wagon (as i like the interior and i used to have a VT Wagon so i know a bit about them). . This is where it changes. . Id like to put either a RB26DETT or a 2JZ GTE motor, gearbox and diff in.
I know it is possible but what one would be better to use. . . im leaning more for the 2JZ as i dont have to worry about all the 4wd bits on the 26 motor and box, making it cheaper. . .
Im open to any ideas on what car or motor to use (no V8s or V6s) Would even consider a rotary. . .
Oh and it would be for everyday use too.
Cheers
Daniel
https://www.sau.com.au/forums/topic/199906-cross-breeding/
  • Replies 68
Go old school. 64 Studebaker Cruiser would make a good looking VIP with the right mods. :P and for towing, you cant beat the V8. (think std they ran a 289 but i would dump that and go Chev....350 would be the better choice as parts are easy and chaep to get) :)
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560114
LOL nah not after a V8. . Im after a turboed jap motor in a newish modern looking car
Edited by Daniel R32
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560123
The studebaker cruiser (64 or 65) could be made to look modern. Google them and have a look. There would be plenty of room in the engine bay to put what ever you want (toyota/lexus V8 perhaps?) a nice coat of paint, tinted windows, big rims etc etc.......it could work :P
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560144
I've seen a 25 in a VS and a 2JZ in a VN/VG ute. Both were alright but I heard the VS was a big of a slug, fairly stock, while the 2JZ was rather extensively worked.
Personally, if I was to buy a VIP cruiser type vehicle that could still tow stuff, I would get a Celsior/LS400 and order a blower kit from the states. Small capacity turbo 6 would suck for towing IMO, blown v8 FTW!
Not to mention that there is some serious engineering to be done when transplanting engines, especially from different manufacturers. What about a gen3 CrossX8 thing? dump it on its' ass, big rims, turbo kit.. :P
Edited by bubba
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560254
What about a gen3 CrossX8 thing? dump it on its' ass, big rims, turbo kit.. >_<
Nah not a fan of V8s yes there good but id rather a 6. And i want the mechanical side of it to be jap stuff not aussie or american. . .
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560626
Prob my old white ute.
I didn't realise 350 ATW was sluggish >_<
hp or kw?:) nah it was a sedan, saw it up at barbagello many moons ago.
1UZFE then, as strong as a 2JZ in stock form.
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560674
no chance of fitting a RB26 into a legnum, its an east/west V6 with the gearbox in the engine bay, so no real transmission tunnel.
the TT V6 in the legnum though has PLENTY of torque for towing though. >_<
or if you still want a rb26/2jz commy, go the 2JZ!
OR if you will settle for a twin turbo V6, chuck a 6A13TT, or 6G72TT in it. :)
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3560884
64 Studebaker...I think I speak for many when I say "I didnt see that one coming" :)
Daniel. Dont know if you could get a 2JZ or an RB in to a VT.
Go a Buick V6 Turboed. Same mounts, same G'box as the Oz stuff, basically Holden used the Buick bottom end but changed the head studs so you couldnt put the hardcore Buick heads etc on the econo pack commode and guys in the states have been making good HP on those combos for years. Maybe look at the Statesman V6- I'm told that that motor is most probably the full Buick Supercharged V6 from the GNX as the head wont go on the econo pack commode. If you that keene on a straight six probably look at something pre VN..mo engine bay.
https://www.sau.com.au/forums/topic/199906-cross-breeding/#findComment-3561183
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
