  • Replies 62
No problem, you'd really need a ECU mate.
Its pretty much the first cab off the rank for mods.
FMIC offers no real performance gain until you upgrade turbo IMO.
Just adds a bit of lag, noticeable or not depends on many factors.
and it makes the car look uber cool LOL
IMO, I would invest in a decent turbo back exhaust system than an FMIC, invest in putting back the stock airbox with the snout and getting a decent panel filter, and maybe re enforce the stock rubber intake pipe.
Mods with gains.
Mods with gains.
Yep, i agree 110% with all that.
Least there is return on investment other than looks
I can't believe I forgot the exhaust!
I have a full 3" turbo-back Fujitsubo exhaust. The pod filter is enclosed in a heatshield (compatible with the stock snorkel). How could I re-enforce the intake pipe? I was thinking of getting a shorter alloy pipe.
Is it really necessary to upgrade the ECU if i'm planning on getting an FMIC?
Thanks.
The ecu will change your fuel maps, timing etc, get the most out of what you have.. You will get more gain out of it than a fmic alone. What might be a better option for the time being is an R34 gtt standard sidemount cooler, I'm pretty sure they are still bigger than the S2 R33s, and can be picked up fairly cheap, and you cant see them. So less chance of the police picking you up for it, and people nicking your car.
Id still go the ecu tho.
Alright, I'll put the ECU on my shopping list.
Since I'm keeping the mods fairly basic, I think I'll go for a piggy-back instead of the full one. Can anyone recommend an affordable (yet) reliable one?
I used to own a Honda Integra Type_R and I knew a lot of about ECU's for them...but very newbie here!
Thanks.
Im in the same boat...about to start to save up for a new ecu. For a brief few moments I was considering a AFC neo but after doing some reading have decided that Im better off just saving a bit longer and getting the Greddy emanage ultimate.
My mods so far are K&N panel filter (im also anti pod), 3" turbo exhaust, and EBC. The boost controller had made a hell of a difference and only running 9psi max. Can't wait to get the EMU and get a good tune!
FMIC's will not give you a horsepower gain by themselves. They will only last longer till they heat soak, and thus they will not DECREASE your performance as fast as a SMIC. Now if you have a big turbo, but couldn't crank up the boost because you heat soak your SMIC really fast, and now you can crank it up (with a tune of course), you'll get HP. O yeah, and like they said, they look cool!
With a aftermarket ECU like AEM ECU, hp gains can be up to 38rwhp
(roughly 28rwkw) with a RB25DET at the same boost level.
Here's a thread on the AEM forum about the 38rwhp gain (need to login
to view dyno chart) -
http://forum.aempower.com/forum/index.php/topic,12517.0.html
A locally made Motec ECU probably would produce similar gains
but needs an adaptor loom.
Just fitting and tuning a HKS F-con pro (similar to Motec ECU) has
seen gains of I think was 20rwkw over PowerFC on a RB26DETT.
On a 2 litre motor, podfilter has a boost gain of roughly around 0.1bar (1.47psi) and 8rwkw.
Exhaust has a boost gain of roughly around 0.2bar (2.94psi) and 18rwkw.
I noticed GTR front mount has seen gains of 18rwkw.
So 28rwkw gain with a ECU vs 18rwkw gain with a front mount intercooler.
Edited by SKYPER
Hey im currently in the same boat as well, at the moment i have a blitz pod filter and a HKS SSQV BOV, now i need is a Blitz LM cooler and a Turbo back exhaust, Where did you get your Fujitsu turbo back exhaust from?
Thanks geraus.
When i got my car 2 years ago it already came with a catback...and the i actually went fmic before any other mods solely because its more of a support/safety mod before i went to any power mods...especially with the blistering summer temps now i think its a good idea...
I'm anti-pod filter!
i couldnt agree anymore. Most pod filters under $30 bucks i found to be rubbish!!!
my first mod was a turbo upgrade :( every car needs a exhaust so that was first but i wouldnt call that a mod..
Edited by rich flavour
i did a few gtech 0-100 runs before and after my fmic installation.
there was essentially no difference in performance
however i did get maybe 200rpm more lag and seemed to have lost a bit of linearity in my power curve.
i wouldnt recommend a fmic unless you're going to use it (i didnt even up the boost...)
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
