  • Replies 265
we'll show em what a real car is :)
baaahahahah im sure our little turbo engines have more torque than alotta those 8's :)
DAMO!! welcome to SAU.... were usually a nice bunch here and i can gaurantee you that between us all we can help u with anything u wanna know and every thing u dont wanna know. u better bring ur 34 down!!!
ok guys here is the good news guy/4door sleeper has offered to take me down and his girl will drive his beast down!! its all coming together.... getting amped!!
:banana:;)
GTROB i tihnk its a near definate that u should come and park with us 15 bucks and correct me if im wrong but i think that pays for a passengers entry too
would be awesome to have another GTR there
:banana:
:banana:
Still unsure If I bring that or the XW GT. Both would be great down there but can only drive one car at a time.
So can I still just turn up on the sunday morning and enter or not. As it will be a last minute thing If I come as I have a 2 hr drive to get to adelaide. And getting down without smashing bugs all over the front of my car isn't the easiest at this time of yr.
Edited by GTROB
yeah between 7:30 and 9:30 if in display..... if uleave at 5 u will make it for the meet at the carwash lol so dont have to worry about bugs
At that hr of the morning I'd be more worried about those big bugs with long tails that hop alot and don't really just leave a little smudge on your paint when you hit them, More a front end write off. :D Geez I hate roos.
Edited by GTROB
ok ill bring my gazebo...last time vu and i tried to set it up there was a bit missing but i think i might have found it...ill set it up tommorow or friday to make sure its all their, otherwise...anyone have duct tape? :D
ill bring an esky too + some drink and half a dozen fold up deck chairs, for myself and all you other bludgers who leave yours at home.
sounds like its going to be a good day.
ill bring my gazebo down too.........have abash at putting it up without the instructions..............
i am borrowing a power box thingo so i can have the stereo going and matty has been able to get hold of a generator for me :D
plus ill fill my esky up with some drinks too.........who wants to bring nibbles? :)
is anyone able to help me bring the gazebo/sau banner down at all? i dont really have any room in my boot and dont want to put anything in the back seat cause im getting my seats and carpets shampooed on saturday morning! hahahaha
oh god plus a generator to bring!
Edited by MissR34
cheers for that dave! not sure how big the generator is yet........will find out soon enough!
anyone heard the techno remixs of the never ending story? inspector gadget?
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
