Hi guys my r33 gtst is currently running 171rwkw with std turbo set at 10 psi SAFC2 walbro pump and cat back kakimoto exhaust hks pod R34 SMIC.
Question is will there be much gain on adding a high flow cat and also a dump pipe (current dump = std).
And what are the cat and dump from JJR like?
Thanks
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/
JJR dump pipe is brilliant ...
excellent fit ... superb flow ...
when i fitted mine up boost jumped from standard 7 psi to 14psi ... which obviously caused issues with the standard ecu ...
the only trouble is that one of the turbo water lines need to be slightly bent to ensure enough clearance.
Just Jap don't make their own high flow cats though they use x-force ones :woot:
best bet ... get a JJR split dump pipe and a high flow metal cat or catco cat :)
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/#findComment-3566658
hmmm i had the same problem with the JustJap split dump pipe so i exchanged it for a Xforce Bell Mouth dump but yeah go the Hi flow cat or maybe the cat replacement pipe? im sure you'll get a gain but as said before the side mount could be changed for front mount i guess....:)
Cheers
Chi
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/#findComment-3566715
his got a r34smic(good for upto 220rwkw on rb20det's) his currently running 171rwkw.
get the combined dump and front pipe and 3" high flow cat dude. whether its a split or bellmouth dump thats up to you.
when you change turbos THEN grab a fmic.
goodluck
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/#findComment-3566746
Some members claim that xforce cats are good...and i have no reason to doubt them...but personally i steer clear from them...
I had one on my R32 Gtst with a HKS2535 and after tune i only got 200rwkw...that was really low and my tuner and i were scratching our heads trying to find the cause of the low power...a restrictive cat was a possible cause...i decided to go for it and shelled out $400 for a Metal cat...immediately the difference was noticeable with boost coming on much earlier and harder...a retune and run on the dyno saw a decent power increase with power rising from 200 to 215rwkw with just the change of the cat and a retune...midrange also improved tremendously...obviously the power gain was also due the the fact that my tuner could dial in alot more ignition timing due to the reduced restriction in the exhaust...but it proved that in my case the xforce cat was crap...
Take what you will from this but i hope it is reason enough to pass on the xforce cat...and as for the dump pipe...yes there will be a noticeable increase so if you don't have one already then go for it...
Edited by limpus
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/#findComment-3566785
I have had good results with the magnaflow ones too...i'd be inclined to go magnaflow over xforce...and recently the metalcats seem to be having a bad rep due to it collapsing...hasn't happened with mine but i'll monitor it...
$250 for a 4" one seems decent...
https://www.sau.com.au/forums/topic/200464-hi-flow-cat/#findComment-3568663
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
