sorry about the long post, but the more info, the less questions.
E.O.I : Make / Model / Year: S3 1988 Skyline Ti (5spd + Turbo)
Kilometers: 121,500km
Transmission type: 5sp manual
Engine: RB30e+T
Colour: 2006 Audi Aurora Blue Pearl (full respray inside and out)
Roadworthy Certificate: No.
Accident History: front quarter hit, cosmetic damage only. Professionally repaired with genuine Nissan replacement panels. Respray done at the same time.
Price: 12,500 k
Contact: Mat, O438 32O 369, matVL30athotmail.com, or via PM.
Modifications:
ENGINE:
- RB30ET
- VLT injectors, newly reconditioned when installed
- KA24 Throttle Body, ported out and matched intake manifold (cruise control still functional)
- Darkhalf ECU
- Bosch 040 fuel pump, 4GA wiring from battery to fuel pump terminals, running off relay.
- 3" exhaust, hi-flo cat, Lukey muffler, with twin 3" dump pipes – very deep bassy note, but legal db.
- 600x300 cooler (sprayed black on one side, invisible from outside car, polished on other side.)
- 2.5-2.75” cooler piping by ExhaustWorx, comes with two induction configurations, high mounted K&N filter, or sik dose pipe.
- Quality Hybrid Silicon hoses throughout all with T-bolt clamps
- Twin GT-R BOV’s plumbed back. Stealthy but effective.
- PWR custom catch can, 90-deg alloy rocker fittings.
- 5 spd Manual conversion
- HD Exedy sports extreme clutch
- 170rwkw @ 9psi and stock fuel pump (now with 040 and upgraded wiring, expect an easy 200rwkw with a tune)
SUSPENSION
Front:
- GTS2 front struts with factory adjustable tops, Bilstein inserts (tested before install 1 month ago), Lovells springs.
- Whiteline strut brace
- completely overhauled hubs, new bearings, seals etc, genuine parts.
Rear:
- HR31 JIC Gold coilovers in rear. Excellent condition, no-knocking.
- Noltec Adjustable Panhard rod.
- Car sits bang on 100mm from ground to lowest point on front-pipe, can go lower with the coilovers if desired.
BRAKES
Front:
- R34 4-spot callipers, 310mm rotors (redrilled and skimmed, only 1mm of wear)
- Bendix Ultimate pads
- Parts installed as new 3 months ago
Rear:
- Completely reconditioned rear callipers
- RDA slotted rotors, plenty of meat left on them.
- Ferodo Green pads
- Parts installed as new 3 weeks ago
WHEELS
- 18X8, 18x9 Work Euroline Type M rims +38 offset, no rash, mint condition, personally imported.
- Dunlop Lemans LM703 Digi-Tyre 235/40/ZR18 fronts (90%) and rears (85%), stretched tyres, sit perfect to the guard, no scrubbing.
- 25mm bolt on spacers front, 20mm rear.
- Also includes stock 4xTi rims mint condition, tyres incl.
EXTERIOR
- Full respray in Sept 05, 2005 Audi Aurora blue pearl (over 300 parts to this paint, it is ridiculous, must be seen to be believed). Paint supplies alone worth 1.5k. Car is straight as a gun barrel. Have had it into the shop twice since the respray just to get small chips and nicks taken out, that’s how particular I am.
- deleted/shaved rear boot lock
- deleted/shaved aerial hole (internal electric aerial installed)
- lipped gaurds front and rear
- Import Coupe front bar
- Import Coupe rear bar
- Import GT autospoiler on custom brackets, motors working, using factory switch in cabin.
- GTS-R lower ducts
- Import electric folding mirrors, wired up in cabin.
- Cut out front bar with black mesh
- Import projector headlights, reconditioned and repainted.
- HID 6000k low-beams, Phillips Crystal Vision globes high-beams, white LED parkers
- R33 Nismo indicators clear
- Import Tail lights and Garnish, mint condition.
- Chrome pinstriping
- darkest legal tint, double on the rear window
- All chrome trims polished.
INTERIOR
- Nismo leather shifter
- Stewart Warner 0-15psi boost gauge
- VIPER top of the line 791XV 2-way remote alarm, many extras incl remote start, turbo timer etc.
- Top of door trims plus A, B & C pillars re-trimmed in navy blue suede.
- All factory Ti options, Cruise Control, Power windows, Trip Computer, Velour seats immac.
STEREO
- JVC Chameleon HU
- iPod aux input jack in centre console
Front:
- Response Kevlar splits 6.5", hidden behind door trims, discreetly mounted tweeters, crossovers mounted in glove box.
- Sound deadened doors, both inside and outside skins.
Rear:
- Pioneer 3-way 6" rears
- Sound deadened Parcel shelf and C-Pillars
Boot:
- 2x12" JL Audio 12W04 subs in carpeted box.
- 1520 WRMS worth of amplifiers. (2 x Response Amps, 4x130WRMS and 2x380WRMS sub amp)
- gold plated terminal RCAs, shielded, used throughout.
- 2GA wiring from front into 4GA wiring in rear, Gold plated Terminals, Stinger distribution block with LED display.
- Full Stinger sound deadening in boot (boot floor, sides, suspension struts, back of seats, boot lid).
- Complete MDF install, incl. false floor, side boards, and rear beauty-board. All carpeted. Featuring stainless-steel halogen down-lights powered off relays. Looks a million bucks with heaps of useable space.
(Stereo is designed for SQL. Over $600 worth of sound deadening has been installed. Bass will shake the rear view mirror loose inside the car, but with the windows up, you can’t hear it outside the car, it’s the way I wanted it. If you want to show off, fold the seats down, put the windows down and doof your head off). Total replacement value of stereo is $2k plus.
Contact Details: Mat, via PM.
Other Comments:
I have got a job offer in the States starting mid-year, don’t know if/when I will be back, so as much as I’d like to store it and keep it, it makes no sense. Price is very reasonable and reasonably firm. Over 25k has gone into this car. If I sell it for any less, then I’m losing more than I’m getting back.
The car in person sells itself, but I will honestly answer any questions anyone has. I have owned the car for four years. And although it has gone through a massive transformation, it has not once missed a beat. Very reliable, very good power, handles like a go kart and snaps heads like a supermodel for all the right reasons. It is tight as a drum, and I have chased down every rattle and squeak and it is very quiet inside the car. And even though I am biased, I doubt you will find a better overall example.
I have put less than 10,00k’s on it in 4 years, and the low k’s are clearly evident in the overall condition of the car, especially the interior. It lives in a lockup garage and washed weekly. Car was not thrashed and abused –I’m a soft-cock behind the wheel and those of you who know me will agree.
Known issues: minimal. If I were keeping it I would do something about the diff, as it is still a single spinner. Fine for n/a driving, but turbo used to present some traction issues. Spool/locker/LSD – up to you. 2nd gear synchro can get over-run if you get brutal on it, but other than that fine. And that is literally all. If I could fault it, I would have already fixed it. Not a cent to spend, and I’m dead serious. I’m happy to show the car to genuinely interested parties, but I won’t tolerate time wasters, tyre-kickers or test-pilots.
Edited by SLYLINER
Good luck with the sale Mat! By far one of the best looking Aus Spec R31's out there.
I know for a fact this car owes Mat ALOTTT of money, the buyer of this car will be a very lucky person.
cheers dean. fishing for offers here. as the white 33 owner on queens pde yesterday can attest, this thing can hold its head up high amongst the grey import crowd. 3.0L vs 2.5L in a 2nd gear roll on.....tsk tsk, should have known better.
Edited by SLYLINER
guys, got a few blokes lined up to look at it this weekend - if you're keen to have a look then let me know. my number is O438 32O 369
Brad from Ballarat, who rang me last week, i have misplaced your phone number mate - if you are still keen to come down and check it out let me know what day suits you best.
air con work?
sure does. re-gassed it 18months ago, its ice cold. cooler has been fitted specifically in a way to retain the aircon.
all electronic options are fitted and working - remember this car was the luxury model of the time, equivalent to a Ti Maxima or something similar today. has working cruise (modified to operate with manual transmission), power windows, trip computer, central locking etc.
Edited by SLYLINER
  • 3 weeks later...
righto, i'm not here to bollocks spiders.
this car needs to sell. i am dropping the price significantly. have had an interested party at the original price but he is taking his sweet arse time closing the sale, so its open to buyers interested at 11k firm. i would rather throw a match on it than see it parted out to a bare shell, but i can't afford to be emotional about this anymore. the car has to go, either as a whole, or in the sum of its parts.
i have had this figure in my head from the start, and if it doesnt move at this price over the next 2 months - the car will be parted out down to a bare shell. at 11k i am losing over 14k on this build, which absoloutely bleeds me. any price lower than this, i will make more off the parts alone. this revised price is as low as i'm willing to go, so low ball me and expect a rude response.
DO NOT EXPRESS INTEREST ON PARTS
. i am not willing to talk to anyone about parts in any way shape or form at this stage. i strictly want to hear from people who are interested in the entire car only.
SO
11k as is
10k without rims, Ti rims fitted
9.5k without R34 brakes, HR31 calipers and rotors fitted.
This has to be one of the cleanest cars I have seen for ages considering its age. Full credit to you for the way it has been presented, lets hope it goes to someone who will carry on with care and attention you have shown.
Gary
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
