Without labour costs, this is pretty much the cheapest forged build you can do:
HKS Forged 87mm Pistons - $1137
Argo forged conrods $1100
HKS Gasket Kit 1.0mm 87.5mm bore - $323
Nismo N1 Bearings - $250
ARP Rod bolts - $100
Block machinging and decking - $200
Head service - $450
JUN Valve guides - $395
Remove and resit valve guides - $240
JUN Strengthened Head Bolts - $400
Cambelt - $50
JUN Oil Pump - $920
All prices taken from Greenline.jp
If you don't do valve-guides or oil pump, you risk doing another motor.
Other things I'd suggest doing while the motor is out:
TOMEI Poncams + Gears - $862
TRUST sump extension - $355
Then you have labour costs on top of that.
Yeah depends on whether you want to do a stock rebuild or an upgrade rebuild. If youre just talking rings and seals an a clean out...? Then there are things like crack testing blocks, balancing teh crankshaft, decking the block, relinishing your cylinder bores etc...
call a couple of places and get quotes for a stock rebuild, a rebuild with a bit more strength and reliability, then for a fairly full on rebuild like the one above.
I think the best answer is, it costs as muc as you are willing to spend to get the desired result.
I had mine rebuilt pretty much back to stock. The only thing I changed was the pistons, I went forged because the standard ones were $2000.
Heres what I had done
Total Rebuild with forged pistons came to $6040.77
Break down of price
Engine reconditioning works: $1012.60, what was conducted is as follows.
-Degrease & hot tank long motor
-Engine block bore & hone
-Surface grind head
-Measure & linish crank shaft
-Dismantle, check tunnels, check conrods, crank & pistons
-Vacum test, dismantle & inspect cylinder head
-Bleed down hydraulic, fit valve stem seal
-Supply main bearings
-Supply conrod bearings
Misc. Parts.
-Set of JE Forged pistons rings inc. $1660
-Full gasket rebuild kit $358.84
Dismantle & Reassemble engine(Incl assembly of head) $799
4 Liters of running in engine oil $32.65
2.5 Liters of Diff oil $20.68
6 Platinum spark plugs $108
Engine timing belt $109
52 Hours labor to remove head and engine, reinstate $1960
engine after it was rebuilt, road test, bed in new rings
& service
As you can see my labour was cheap so you may/may not have to add a little there.
Hope that helps
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
