Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
Hm yeah, I didn't thought of that, I should've as I got paid @ 15th too..
If everyone no objects then I will change the closing date to 16th July, extra 3 days won't hurt... and will allow more ppl to join in this one...
Sorry, no credit facilities. Do it 16th morning (over branch deposit is even better), or if you must do credit, Paypal is the only way PLUS 3% surcharge. I have no choice to impose a surcharge as Paypal just cost me too much and is a cunning way of eBay monopolising the online auction market.
Hey. I got on the last GB. Only got them on this week. They are stopping on a dime! I highly recomend the upgrade guys. A suspension upgrade is wise to do as well.
hi Rianto thanks for quick reply did you get my 2nd pm
requiesting price for
R33 GTST rotors front and rear slotted and would there be the discount for buying 4pads and 4 rotors
thanks
Steve
Next Group Buy 33 orders:
1. Mr Moo (payment cleared)
2. MotoMan (payment cleared)
3. daemon667 (payment cleared)
4. bombtrack (payment cleared) ** Secured the last pair of the first 4 pairs available for front R34 GTT rotors **
5. Madaz (waiting for payment to clear)
6. Jet-25L (waiting for payment to clear)
Time to be closing the Group Buy 33 orders:
5. Madaz (payment cleared)
6. Jet-25L (payment cleared)
7. Kah Chong - RX8 (waiting for payment to clear)
8. WRRR (payment cleared - confirm total price incorrect?)
so because payment has cleared will they be shipped tomorrow?
i know you cant gauge how long the shipping process will take, but trying to gauge if i will get them by friday (not that there needed that urgently)
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
