Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
Hey Rianto,
Just wanted to say thanks for organising the group buy. I got my rotors today! look awsum.. I want to chuck them on tommorow... but need to get some new pads... I hope these slotted get rid of my horrible squeal!!
just outta curiosity... could you give me a pm for the pads aswell...
otherwise.. i am a poor bastard being a uni student and all.. which one would you advise out of these...
bendix general, ultimate, qfm premium... or any other ones you can get around the auto stores... Im pretty sure they are all rubbish...just want to know if any are slightly better to go with these slotted rotors..
oh and one more thing.. to clean off the oil on the new rotors... degs??
Kind regards,
Adam
^^ Give Brake West a call for QFM K500's i sourced mine in adelaide for cheaper than eBay
and degreaser might work but there is a product called brake cleaner might be a stronger form of degreaser im not sure
Swapping rotors alone may not solve noise problem. noise are mostly caused by uneven surface btwn rotors and pads, they get worse as the rotors/pads gets older and becomes uneven.
Other factor is bad install. I had people kept complaining it's their brand new pads and rotors that caused the noise but when their car finally get looked at by a real experienced brake mechanics, a simple take off and re-fit, with no additional of any brake goos, the noise just gone. If you fit new pads to old rotors, make sure the old rotors surface is checked and machined if there are grooves on the old rotors.
Believe it or not there are lots of 'dodgy' backyard brake install that could have caused the noise. Of course there are cases where some unknown chinese brand pads or rotors on ebay are the real culprit because you just don't know where they are made and whether the manufacturer made them with strict standards. All RDA rotors & EBC pads (UK) are manufactured to ISO standard and very unlikely it is the failing component.
Make sure you clean the rotors nicely before putting it on. a natural mineral turpentine (avoid very harsh chemical) mgiht work, with some old rags - lots of old rags perhaps :P that's how I cleaned mine. If not, then the oil will slowly burns away everytime you brake and a horrible smell and smoke might come out.
I'll pm you about the pads sometime tonight... I got a lot on at work today.
Thanks for the advise guys,
I got the standard rotors machined, bought all the types of pads you can get at bursons etc... bought the goo.. all still squealing... went to brakes plus in burwood.. they gave me qfm pads and professionally installed em.. ( i watched what they were doing) - everything the same as me......they were ok for the first month.. now they are just shocking...
apparently the guys there said the rotors kept glazing over??? due to me being really light on the brakes about 95% of the time... i thought that was a load of crap cuz isnt it better to be light on the brakes?
if i were to get some pads tonight from a car parts place... any reccommendations?
i await ur pm.... :(
Thanks,
Adam
i await ur pm.... :P
Thanks,
Adam
During bedding in new rotors, the process sometimes need to be reasonably 'violent', involving a few hard stops from 60-80km/h, followed by a few series of mild braking, then a few hard braking again. that should remove any residues sittin' on top of the rotor surface.
ive heard even from as high as 100kph then hard on the brakes not stopping to about 15kph and repeat untill you smell brakes or your loose brakes (not completely obviously)
Hey Rianto
Just wanted a price check on set of front and rear slotted rotors for r33 gtst s1 with set of green pads for front and rear r33 gtst s1.
cheers m8
I was so impressed with the group buy that I decided to write a guide on how to install your new rotors:
Tools needed:
- Rubber Mallet
- Pliers
- Sockets (22mm and 12mm)
- breaker bar may be required
- Hand cleaner (trust me here!)
- Brake Cleaner
- Flat head screw driver
Firstly jack the car up and remove the rims
Remove break pad wire at back of caliper. Surprisingly this can be tough. Might need a bit of plier action!
Tap out pad pins from behind the caliper with mallet.
This will then allow the Pads to be removed via the top of the caliper.
With the pads removed, now unscrew the 2 bolts holding the brake line bracket in place.
Then (here you might need a breaker bar) undo the two 22mm bolts that hold the caliper on.
The caliper should now be loose and you can remove it. I found a bucket around the same height that I could rest it on. This saves having to remove the brake lines.
With the caliper off, the rotor should come loose on its own. Might need a hammer with the mallet or just screw in a bolt as shown below:
This is the comparison between the old and new rotor. Nice!
While the rotor is off, this is a good opportunity to use rust converter on the hub section. This should help the rotor come off cleaner next time too for machining or replacement.
Put the new rotor on and screw in 2 of the wheel nuts to hold it in place.
Reverse the above process to get the caliper back on.
Any questions feel free to PM me.
Hey dude
I need front and rear rotors, plus pads for a SII R33 GTS25t, just the slotted rotors, and good street pads.
Please PM a price
Shipping is to BROOME WA 6725
cheers for the GB
Isaac
Edited by EvilINGT
Due to forums down, I'll extend Group Buy 35 Orders:
This order have been sent out today:
1. thebuzz (payment cleared)
And the following will be sent out soon:
2. jvs007
3. blk r33 gtst
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
